Question about Microwave Ovens
Emerson microwave door latch - Microwave Ovens
Drummernick
  • 440 Answers
SOURCE: door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
Posted on Feb 10, 2008
  • 6 Answers
SOURCE: Door won't latch/microwave won't turn on
The door does come apart. Open the door and where the hinges are, there are openings where the hinges enter the door, this plastic piece (goes all the way around the door) With a small flat blade screws driver VERY carefully pry it (plastic) off, once off, check the latch end for the spring, typical failure for a Sharp is the little tab that the spring hooks to on the door, the only way to repair this so it will last is to replace the door frame. they are not too expensive, about $50 or so Part# FCOVB166KIT
is the door frame assy
Posted on Jan 07, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp R-308J microwave door will not latch
If you gently push up on the door latch head assembly (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Posted on Jan 12, 2009
jsrock516
  • 5911 Answers
SOURCE: Broken door on my Emerson microwave (MW8985W)
You can order the outer panel. Its available at searspartsdirect.com for about $41. Just type in your model number and look under the "Door Assy" heading. To replace, just follow these steps:
You have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Remove the door handle and any screws that may be holding the outer panel in place. Some panels are simply snapped in place.
Remove the broken panel and install the new one. Re-install the door handle and re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you
Posted on Aug 28, 2009
MNfisherman
  • 11896 Answers
SOURCE: Microwave will not cook/start when start button is pressed.
You can get the latch itself from either partstore .com or repairclinic .com
Posted on Apr 19, 2010
I have an Emerson Microwave Model #MW7300W, it appears that a small hook on the Latch is broken off of. This hook holds the spring that allows the hook to hold the door closed. I have tried looking
If this is a .5-.7 cubic foot cheapy, your only source will likely be an appliance boneyard. Otherwise, check with searspartsdirect web site using the model # for replacement parts. You can also check with Emerson web site {I beieve it is part of the Funai electrical empire}
Jul 22, 2014 | Emerson Microwave Ovens
Door latch on Emerson microwave oven
Feb 10, 2008 | Emerson MW8987B/W Microwave Oven
I have an Emerson MW8999RD that all of a sudden yesterday wouldn't latch. I don't think you have to, but I took the door off (three screws hold the case on which needs to be removed to get at the top hinge). Then I took off the inner plastic picture frame - pretty easy with a thin blade to move the fragile tabs. Then I removed the metal frame that has the little microwave blocking holes. This was the hardest part because the plastic retaining tabs are even more fragile and I broke one. Then I found the loose spring due to broken plastic hook as described above. I was able to make a new hook by simply looping a small zip tie where the old plastic hook tip broke off. Now works great!
Aug 22, 2013 | Microwave Ovens
Door not closing
If the door is not closing, the door latch is broken at the tip, or inner mechanism, or the door is out ot of position and not lining up.
Mar 05, 2012 | Emerson MW8987B/W Microwave Oven
The the top latch on the door is not closing the door and preventing the microwave from working. Can you tell me how I can get it fixed?
Remove the cover and take a look at why it is not latching. I suspect there is a catch that is broken. Find replacement latch at your local appliance parts store.
Thanks for your question today.
Mar 02, 2011 | Emerson Black Microwave Oven
Apr 19, 2010 | Emerson MW8168B Microwave Oven
Door is not open
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be
removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Many Emerson microwave manuals are available for free download here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Emerson Black Microwave Oven
Emerson microwave: Control buttons work microwave does not
Consult your manual, but it might be in demo mode. Unplug it for about 10 minutes to see if that would help.
Mar 01, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
