Question about HP Photosmart C6180 All-In-One InkJet Printer
C6180 error 0xxc18a0106 - HP Photosmart C6180 All-In-One InkJet Printer
Ink system failure
A Google search found this possible solution for you at HP:
Ink System Failure C6180 error 0xc18a0306
Jul 25, 2014 | HP Photosmart C6180 All-in-One Printer,...
How to override error Oxc18a0001
If you have a C6180, the error code you give here is not in the manual, so you better contact HP service centre like the manual explains.
Jul 21, 2014 | HP Photosmart C6180 All-In-One InkJet...
I have a C6180 printer with the error message "ink
I had a similar Ink System error occurring on my printer and eventually it would constantly power on and off. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers.
Nov 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error is "oxc19a0035
I have a C6180 that was displaying the 0xc19a0035 error code and the above fixes worked for a while until the printer started power cycling continuously - making it useless. The problem turned out to be failed capacitors on the logic board from a manufactuer called TEAPO - many unfavorable internet references. Look at the capacitos on the logic board, if any look like they have even the slightest bulge in the top, they are failing and should be replaced - see image. On my C6180 I replaced C613, C614, C660 and C662 and the printer is working great!
Aug 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error Oxc19ac3ff how to solve it ?
It would help if you could specify what OS your computer has and what product emits this error, but there's a generic problem solving wizard at the HP web site for the Photosmart C6180
Please give it a try.
Apr 11, 2010 | HP Photosmart C6180 All-In-One InkJet...
I am having a problem with by printer C6180..error it is giving is ink system has failed...error 0xc19a0035
call HP support. They will give you a series of codes to enter into the keypad. They are the only ones that can solve this problem.
Dec 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 all in one, does not copy or print anymore.
put the old cartridge back, if there have same error message then tell me what error message is, if not that's mean new cartridge is defect.
Dec 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure
below is to document that i want you to follow exactly inorder to resolve your issue..
CLICK HERE ==>> DOCUMENT
Please let me know the result after following the document.
thank you so much.
adonscott
Aug 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
21 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
