Question about Gateway FPD2275W LCD Monitor
Eztune download - Gateway FPD2275W LCD Monitor
How to restore eztune
Funny you should ask. I was just reading my Gateway monitor manual this afternoon and it says you can download EzTune software from http://oem.portrait.com/dtune/gwy/enu/upgrade.html. Be sure to to download the right software for your monitor. Apparently there are different versions for different monitors
Dec 17, 2012 | Gateway 19" Widescreen Flat Panel TFT LCD...
Cannot uninstall eztune My new gateway monitor had eztune that didn't work so I downloaded another and it says it is incompatible and That I have an older version running and need to uninstall but I...
Please follow the link below to download Microsoft Uninstaller Cleanup Tool.
Save this program to your Desktop, and then install it. The file should be named "msicuu.exe". Once it is installed; follow these directions.
1. Open C:\Program Files\Windows Installer Clean Up\ or if you are running a 64-bit Windows Operating System: C:\Program Files(x86)\Windows Installer Clean Up
2. Here you will find the msicuu.exe program. Run this program by right-clicking on it and choosing "Run as Administrator".
3. You should see the Windows Installer Clean Up window open.
4. Find the entry, (All Users) EZTune Monitor and left-click on it once to highlight it.
5. Locate the "Remove" button below and left-click on it.
6. After a breif moment, the program should be removed.
7. Close out of Windows Installer Clean Up; and run your downloaded EZTune Monitor program again. It should install now.
Aug 28, 2011 | Gateway Computers & Internet
Monitor message says "Theft Disable
The theft deterrence system can be disabled temporarily by unplugging the monitor's power cord. Then it will start the counter again. (The default is 60 minutes and is set in the EzTune software.) The software locks the monitor to one computer (the one running the EzTune software). To disable the theft deterrent message, enter EzTune and click on the Extras tab. Then select the Theft Deterrence section and enter the PIN. The PIN can be saved online and then you can request it if forgotten: https://pinreg.portrait.com/index.php?OEM=gwy&PRODUCT=dtune&ULANG=enu .
The EzTune software is available here: http://oem.portrait.com/dtune/gwy/enu/upgrade.html .
The user's guide and other documentation is available here: http://support.gateway.com/s/MONITOR/7005574R/7005574Rnv.shtml .
I hope this helps.
Mar 15, 2011 | Gateway FPD1975W 19" LCD Monitor
My monitor doesn't let me type in the password. If i click to change the password it asks me for a disk on which the password is supposedly stored. I don't have this disk, I don't racall the monitor came...
This monitor includes EzTuneā„¢ which is part of GatewayShield's hardware protection solution.
This theft deterrent software lets you use a unique PIN code to secure your monitor
to your PC. If your monitor is removed from your PC, your monitor will not
function. To get started, install the EzTune software from the CD, go to the
Plug-ins section and enter your personal identification number. If you decide
to move your monitor to another PC, make sure that you install EzTune on the
second PC and enter your PIN or disable EzTune within GatewayShield on your
original PC before you disconnect your monitor from your PC
Dec 14, 2010 | Gateway FPD2275W LCD Monitor
I have a Gateway FPD2185W monitor with a NVIDIA Gforce 9800 GT. Software was delivered with this monitor to suppor the Pivit features. I have had a few problems with IE since that time, but nothing I could...
The Pivot software is part of the EzTune application. When you installed EzTune, it automatically configured itself with your currently installed drivers. When you update your video drivers, Pivot must reconfigure itself. This is normal operation.
EzTune version 1.4 and later is compatible with Windows Vista.
The latest version of EzTune can be downloaded from the following Web site.
Hope that helps...
Apr 11, 2010 | Gateway FPD2275W LCD Monitor
Gateway FPD2185W-UK with Vista Home Premium. Problem is finding latest EzTune does not recognise the monitor and the version that came with the monitor (V1.0) will not work with Vista? Any help greatly...
The problem with EZtune is usually with it not being compatible with the video card of the computer.
You can go to
http://www.portrait.com/dtune/gwy/enu/compatibility.html
and see if it is there
You can also get the latest downloads at this site.
Fran
Mar 28, 2009 | Gateway 1532121 Monitor
Doesn't rotate and doesn't go into high resolution
have you installed the software for the monitor and the drivers
Aug 19, 2008 | Gateway FPD2185W 21 in. LCD Television
I have EZtune on my computer in theft mode. I can not find my disc so I can not enter my PINJ. Please help me
Find your disk and reinstall.
once in theft mode EZTune will lock you out.
good luck 44hink
Jun 03, 2008 | Computers & Internet
Gateway 22" Monitor
hi there! well, EZTUNE should be a mac version, so it could play to your macintosh computer also. you can download the mac version at torrent sites, just be patient searching it.
Sep 12, 2007 | Gateway 1532121 Monitor
Gateway FPD2275W LCD Monitor Logo
60 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
