When i press on the bluetooth button it does not turn on it also does not show up in device manager
SOURCE: Acer Aspire 5310 Bluetooth Heeelppppp
I Also have the Aspire 5310 and when you press the bluetooth launch button it says 'No Bluetooth Device', this is becasuse it does not have the Bluetooth card installed into this computer and this is an extra for your laptop... hope this helped.
Thanks
SOURCE: bluetooth on aspire 4730Z
The 4730Z does NOT have bluetooth. Check the specs on it from acer's website. The reason for the buttons are that it share much hardware with the 4930 which does have bluetooth. You will need to add a bluetooth device if you want bluetooth.
Once again, the a4730 doesn't have bluetooth in it's stock form.
SOURCE: Acer aspire 6920
I had this problem too and I called acer and found out that the software is not on the computer. You have to buy the usb bluetooth connector thing. I thought it was stupid of them to put this button on the computer and there is no use for it. Just a thought. If anything, call acer yourself and they will explain it better than I can.
SOURCE: acer aspire 5335 no bluetooth? XP
go to control panel then find add hardware. There, it can manually detect the hardware.Thanks and God bless^_^
godlover
SOURCE: Acer Aspire 4520 Wireless Not Working
Reinstall the atheros driver or install broadcom 802.11g network adapter driver given with cd along with laptop or download it from acer.com
