Question about Samsung B2330 23 inch Monitor
How to open a samsung monitor syncmaster B2330
My monitor is flashing and we don,t know how to deal with it, and I want to see inside. thank you.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 149 Answers
Try separating the wiring. Touching wires cause cross-talk of signals.
Posted on Jun 22, 2014
  • 555 Answers
SOURCE: How to open the back cover of Samsung SyncMaster 794mg CRT .
"Don't kill yourself just to save some bucks"
Here are the instructions:
http://www.josepino.com/?open-samsung-back-cover
Posted on Aug 29, 2009
Testimonial: "very thanks...."
  • 555 Answers
SOURCE: how to open monitor samsung syncmaster 753s?
  • 555 Answers
SOURCE: How to remove back cover of monitor
Here are the instructions to open the monitor:
http://josepino.com/?open-samsung-back-cover
Good luck.
Posted on Sep 04, 2009
  • 406 Answers
SOURCE: How do you open up Samsung LCD 740N monitor?
This monitor contains a latches to open. Its recommended that you use suitable tools and service manual.
If the unit is in warranty its recommended that unit to be serviced by service Engineer.
Posted on Dec 30, 2009
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
ViewSonic LCD monitor displays "No Signal Digital" message
There is something wrong with the main logic board. The firmware thinks that there is a DVI connector installed. Such problems with other devices are fixed by reflashing the firmware. But I don't see any connector on the board for that purpose.The faulty flash memory chip is marked with "A", meaning there is flashed the "A" firmwre version of all possible versions - probably this with only VGA connector. My suggestions are: try to find similar working logic board. I didn't find any on ebay, but you may find somewhere else. The other option is hard one - to try installing DVI connector on this board. Unfortunatelly we don't know the parameters of the parts needed. There have to be several diods, some capacitors and a transistor, all SMD. There is also a missing 8-legged IC probably connected somehow with the DVI. :(
Just for case carefully inspect the cpu legs for bad solder.
Apr 07, 2012 | ViewSonic Graphic VG2021m LCD Monitor
Sony kf-ws60s1 front red light flashes 6 times after lamp replacement. Need thermal fuse part number
hello!
your issue has nothing to do with "thermal switch". while you have replaced the lamp, you could lose a piece of plastic hardware, in front of the lamp housing. It pushes auxiliary interlock switch, right under the front of the lamp compartment. If you take lamp out, use flashlight and shine inside. There is a little switch at the bottom. Try to make the lamp housing push it, without breaking anything. you could get "generic" lamp with housing, which is not correct. Anyway, that's the deal. Also: don't forget to install lamp door and turn the handle clockwise! there is another switch. I've seen people who forget to put that door back! Really!
good luck,
Alex.
Mar 06, 2012 | Televison & Video
My husband's monitor is a Samsung LCD 19" and it
Hi!
Does it have warranty? If so, you can contact your monitor provider to check it with their technical support personnel. If the unit is out of warranty, check if it has power or the power indicator is responding. If responding, try pressing the auto configure button.
Check if the monitor cable is OK. If you have spare working monitor, you can isolate the problem.
If the monitor has the problem, there is a deffective capacitor inside it or a portion that needs to be re-solder.
thanks
Jun 23, 2011 | Samsung Computers & Internet
No picture. flashing green light. I can see a flahing, faded image at times.
this sounds like the lcd inverter inside the monitor is going bad. You can take it in to a repair shop and see if they can fix it but with the labor and parts it might be cheaper to go out and buy a new monitor for cheap especially since black friday is coming up you should be able to get a great deal on one. And it will have a warranty.
Best of luck..
Nov 18, 2010 | NEC MultiSync 1550V 15" LCD Monitor
The power button is flashing on and off. get no image believe it is in saver mode, don`t know how to get it out. samsung monitor.
It is more likely to have problem in the power supply section, look inside for bad caps first then post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 29, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
I have a soyo computer monitor, flat, 19
packldr, If your certain that the monitor is not going into sleep mode, you will need to find out where the possible bad solder joint might be. This type of symptom could be a "intermittant thermal fracture" of a solder joint on an internal printed circuit board inside your monitor. Your monitor works fine until the internal temperature rises enough to cause "thermal expansion" to cause a OPEN connection on some critical component on a "switch-mode-power-supply" or "cold-cathode-fluorescent-tube" power supply circuit. (INVERTER ckt) If you visit youtube, check for videos that deal with "LCD monitor repair" and "bad capacitors", "LCD disassembly" just so you know what you are dealing with. Please let me know if this was helpful to you. I'm louie12fix on fixya or lmistyrel@aol.com Bye for now.
Oct 01, 2009 | Soyo Computers & Internet
I have a Proview MA-782KC 17" TFT Monitor and when I switch it on the green power light flashes but nothing is appearing on the screen. When it was working properly the green light remained aon all...
I`ve opened it up and there are several 470uF capacitors in the power circuitry which are obviously bulging, meaning they are in considerable distress. I am ordering some replacements and will fit them when they arrive and see if they get it working. I`ll let you know :)
By the way, I don`t recommend this for anyone not versed in this kind of repair. Messing about inside the power circuit of a monitor can KILL - even unplugged, unless you know what you are doing, so please take care.
Sep 09, 2008 | Computers & Internet
Screen lit up, but nothing displayed (black)
Hello Frank, I have the same problem with my monitor. I don?t have the answer yet to resolve the problem. if you want the first of us who find the resolution will advise the other. I sent an email to Xerox to get the info to remove the cover without breaking it. regards Sylvain
Sep 01, 2006 | Xerox XG-91D 19" LCD Monitor
Samsung B2330 23 inch Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
