Question about Philips SRP4004/27 Universal Remote Control - SRP4004 TV 30 ft, Vcr, DVD Player, Satellite Box, Cable Box, Blu ray Disc Player, Dtv Tuner, Dvr
Dvd vcr device codes - Philips SRP4004/27 Universal Remote Control - SRP4004 TV 30 ft, Vcr, DVD Player, Satellite Box, Cable Box, Blu ray Disc Player, Dtv Tuner, Dvr
IVE GOT THE CODE, NOW HOW DO I PROGRAM IT? CANT REMEMBER THE PROCESS AND STEPS?
Hello April,
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., VCR/PVR,
DVD,CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume,and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 36) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
code in the following boxes:
VCR/PVR Code:
Device Type:______________
DVD Code:
CBL/SAT Code:
TV Code:
You can rate my answer if you appreciate my help.
Thanks!
Oct 17, 2011 | One For All URC4220 Remote Control
Looking for code for my sylvania tv for my one for all access 4 u remote
Hello
Universal remote codes for Sylvania TV with One for all URC - 3300 remote control are:
0054, 0030, 0171
On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
selection, volume, and DVD functions.
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
OK.
Jul 13, 2011 | One For All URC-3300 Remote Control
Necesito intruciones del este urc-3021bg1 para programar el televisor vizio.
From the Manual:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR, CBL/SAT,or TV). NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3 . Press and hold SET until the LED (red light) blinks twice, then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
For VIZIO TV try one of the following codes: 1758; 0178; 10178; 627; 502
Mar 04, 2011 | One For All URC-3021 Remote Control
Instructions on how to program
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thank You
Sep 18, 2010 | One For All URC4220 Remote Control
I need help to get a code for my sanyo tv and how to set it up.
Hi
Configuring codes:
CBL/SAT or TV).
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
blink twice.
Code for sanyo tv is 0154
Thank You
Sep 13, 2010 | One For All URC-3021 Remote Control
I need to program the one for all URC-3021B00 to my sony tv
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Code for sony tv are 0000, 1100, 0810
Thank You
Im trying to program a remote the tv is a zenith
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
Hello. I have a model # URC-4640Boo and am trying to set it up to work an a Sony dvd-vcr combo model # SLV-D300P and can't seem to find out how. Can you help me?
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Thanx
Jul 17, 2010 | One For All URC-4605 Remote Control
How can i put the code?
POR FAVOR NECESITO EL CODIGO PARA TV SANSUNG, SIN ESE DATO MI CONTROL NO SIRVE
Mar 19, 2010 | One For All URC-3021 Remote Control
Philips SRP4004/27 Universal Remote Control - SRP4004 TV 30 ft, Vcr, DVD Player, Satellite Box, Cable Box, Blu ray Disc Player, Dtv Tuner, Dvr Logo
13 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
