Question about Toshiba Satellite L655D-S5050 Replacement Laptop Power AC Adapter / Charger (91812010844)
Toshiba Satellite L655-S5050 Bios Password Removal How To
sandrew
  • 2961 Answers
SOURCE: removal of bios level password
Some laptops are passworded default at'oooo' or 'ooooo'. The bios re-set is the 'JBAT1' terminal, from jumpers 1-2 to 2-3 for a few seconds and then back to 1-2 again, but where the terminal is exactly on your motherboard i do not know. You may also try removing the bios didc shaped battery for 15 minutes or so, then replacing.
Posted on Jan 07, 2007
  • 10406 Answers
SOURCE: how to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
Posted on May 27, 2009
ginko
  • 19396 Answers
SOURCE: toshiba a120 bios password
It cannot be removed using software.
To remove the password you will have to remove the CMOS battery located on the lower side of the motherboard.
To access the battery the computer must be disassembled completely.
toshiba satellite pro A120 opening guide - Digital World
Laptop Disassembly Help
Posted on Sep 05, 2009
  • 66 Answers
SOURCE: I need the bios reset password for a toshiba laptop
there is no actual password. you need to remove the ram and short out two pins underneath the black plastic they look ike two E's connected like E3. use a flat blade screwe driver. do this while powered off!
Posted on Nov 04, 2009
mariolands
  • 2296 Answers
SOURCE: how do i reset the bios or Current password of
To reset the BIOS read the information from this link: http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
Posted on Apr 07, 2011
Why won't my Toshiba Satellite L655 laptop connect trough HDMI anymore?
Check your settings,both bios and display,for the display priority.Either the settings has been set to inbuilt display and thus cant display on external monitors or the external monitors have been disconnected in bios settings
May 15, 2014 | Toshiba Satellite L655-S5101 Laptop
How to unlock hdd/ssd password on toshiba satellite L655
I don't know the current password, how do I reset the current password
Oct 07, 2012 | Toshiba Satellite L655-S5096 Notebook
How to get around lost bios passwork on Toshiba L655
Read the Manual.
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals and search them for Bios Password.
May 26, 2012 | Toshiba Satellite L655-S5101 Laptop
Satellite l655 blue screen password
This is a BIOS or HDD password. I'm assuming you cannot get into "setup"right when you fist boot the system? You will probably have to flash the bios or reformat the hard drive (or both) These are more advanced procedures, I recommend checking craigslist for a local PC technician.
Jan 04, 2012 | Toshiba Satellite L655-S5101 Laptop
What's your problem I NEED MY BIOS PASSWARD
To reset the Toshiba BIOS password, use software
ACPI Flash BIOS version 2.30 for Satellite L655
(support for model L655-S5101, etc)
Important
1. This release offers the option to install the BIOS directly from within Windows operating systems. To do so, simply select the 'Windows Installation' option from the Launcher menu, and click 'Ok'.
2. Please close all programs before executing the Windows-based installer.
3. It is REQUIRED that the computer be connected to AC power via the AC adapter, and that the power-save mode is set to 'Full Power' or the equivalent while installing the BIOS.
How to use:
1. Download ACPI Flash BIOS
2. Double-click the file sk2cv230.exe - select install
3. After the install is complete, the image will appear as below. Highly recommended you read the instructions first, or you can select Install from Windows.
4. Click OK. Do you want to upgrade the BIOS - Yes
5. After the update completes, the computer will automatically shut down or restart. Power on the computer if it is off. While the "Toshiba" LOGO is displayed, press the F2 function key to start BIOS Setup. Check the version of BIOS and press the F9 function key then Enter to load setup defaults. Press the F10 function key then Enter to save settings and exit. The computer will automatically reboot.
Nov 17, 2011 | Toshiba Satellite L655-S5101 Laptop
Describe your Satellite L655-S5101 15.6"
You don't. Updating your bios can really mess up your laptop if done improperly and keyboard issues will be the least of your trouble at that stage.
What kind of problems are you having exactly?
Sep 12, 2011 | Toshiba Satellite L655-S5101 Laptop
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite L655D-S5050 Replacement Laptop Power AC Adapter / Charger (91812010844) Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
