Question about GE Profile Spectra JGBP90 Gas Kitchen Range
317b6641p001 oven remove oven door
I have a GE 317b6641p001 and burners light but not the stove...any help out there?
do you mean oven doesnt light?
may have a bad oven coil
not hard to change just a few screws
remove and check power
Jan 04, 2015 | GE / Hotpoint Stove Top Heating Element...
Ge range 317b6641p001
Get an oven thermometer to see how off the temperatures really are.
Dec 17, 2013 | Kitchen Ranges
Ge hotpoint 317b6641p001
It may be necessary to replace the thermostat.
Nov 28, 2013 | Kitchen Ranges
My GE XL 44 oven will not come on
Does the igniter glow white hot when you try to start the oven?
Apr 04, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
Hotpoint self cleaning oven
1.get pet birds out of house.
2.take racks out of oven
3.slide door latch over if you have one(door should be locked)
4.push clean on control
5.set hours by pushing the arrows.i would set it for 2 hours
6.when finished let it cool down when it is cool enough the door will unlock or you can push the door latch back.at this point you will have a gray ash on everything,just wipe with paper towel.
7.be pround and smile at your clean oven.
8.oh don't forget to bring your birds in if you brought them out,the reason you have to bring them out is because the fumes are toxic to birds,but not to humans.
hope this helped
Sep 22, 2008 | Hotpoint RGB745 Gas Kitchen Range
I have a GE Profile Gas/Electric Oven Range that has stop working
P7 means Shorted Matrix Key. Power down and power up control. If the fault condition reappears within 15 minute - replace control. I got this off a wiring diagram that was in an envelope attached to my range.
Nov 21, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Pilot heats up but gas will not come into bar with little holes in oven
Check the voltage at the oven gas valve, if you are getting 120v, then you have a bad gas valve.
Aug 08, 2007 | GE JGRP20 Gas Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
19 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
