Question about Interface SiliconDust HDHomeRun Network-based Single Digital HDTV Tuner HDHR-T1-US Ethernet Interface
How do I connect a HDHomeRun HDHR4-2US to a Sanyo TV DP50842?
  • doug stahnke
    doug stahnke Feb 08, 2014
    It's a Windows 7 PC, with an Intel wifi atenna.
I have a Sanyo 50" Model DP50842 and when I turn it on I get a no signal display for a couple seconds. It also does it when I change the channel. Is there any way it can be stopped?
The reason it does that is the signal level from the antenna is borderline usable. Either re-aim your antenna or get an amplifier for it.
Jan 02, 2017 | Sanyo Televison & Video
Is there a way to test each board individually on my tv? What could be shorting them out?
pitch this thing into the dump or get a professional to troubleshoot it, it has several bad components that are burning other things our, get out while you can.
Nov 09, 2015 | Sanyo Televison & Video
I have Sanyo TV model DP50842 all the buttons on TV stopped workin it will turn on when plugged up
Main system control memory IC fault. Replace it. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 27, 2014 | Televison & Video
Led blinking red on a sanyo dp50842
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 05, 2013 | Sanyo Dp50741
Is it possible to program the remote from the Blu-ray Disc player Panasonic BMP-BDT110 to control a Sanyo DP50842 TV?
No. Blu-Ray players can't be programmed by any other remote controls. They can only be operated by it own remote control.
Nov 04, 2012 | Sanyo Televison & Video
I have a DP50842 Sanyo LCD tv. does it have a digital tuner built in? if so how do i use it?
Here are the specs, it has a digital tuner:
http://us.sanyo.com/LCD-Televisions/50-Class-49-5-Diagonal-LCD-1080p-60Hz-HDTV
If you do not have the owner manual google the model number with "manual" to try to find it.
Nov 04, 2012 | Televison & Video
Interface SiliconDust HDHomeRun Network-based Single Digital HDTV Tuner HDHR-T1-US Ethernet Interface Logo
73 people viewed this question
Top Interface Computers & Internet Experts
David Payne
David Payne
Are you an Interface Computer and Internet Expert? Answer questions, earn points and help others
