Question about Saws
Tradesman bts10bw table saw
Blade will not raise
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
efs_perpends
  • 1996 Answers
SOURCE: Dado blade installation
Yes. normally an eight inch stack dado set is used on a 10 inch saw. You will also have to purchase or fabricate a special throat plate (non-metallic) to accomodate the extra thickness of the dado set.
The number of blades used, and therefore the thickness, varies depending upon the task at hand.
Make sure to use the factory supplied nut and washer to capture and tighten the dado set securely on the arbor.
Be very cautious in the use of dados. Do not raise the set higher than 1/4" or so until you are familiar with the use of a dado set. Try to avoid so-called "wobble" dado sets. They are IMHO more prone to dangerous kickbacks and harder to adjust than a stack dado set with dado shims.
Posted on Mar 24, 2009
  • 59 Answers
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
Posted on Apr 25, 2009
SOURCE: need a owner manual for tradesman bench table saw model 8031
I believe I have the manual for the 8031 table saw. Are you still looking? Contact me at HollomannAFB@yahoo.com
Posted on Sep 12, 2009
  • 384 Answers
SOURCE: How do I align the saw blade with the saw table
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Posted on Sep 15, 2009
Ridged wet saw beast how to raise blade
Hi John, The link below is a web page about ridged wet saw beast, J Hope this helps.....CHEERS..
Ridged wet saw beast Google Search
Apr 05, 2016 | Saws
How do I raise and lower the saw,.
if it is a table saw, there is a crank on the front that raises and lowers the blade. there should be another on the side that angles the blade.
May 26, 2015 | Saws
Blade on table saw will not raise
typically this is a thrust washer issue. need to look at the play between raise and lower..also ensure trunion is cleaned and lubed.
Dec 27, 2013 | Bosch Power Tools Bosch 4100-09 Worksite...
Price for tradesman bench table saw model bts10bw
Used $50 in great shape...really would be best to look at new, I've a fair bit of probs from these.
Jan 07, 2012 | Delta Saws
How to raise and lower saw blade
You raise and lower the table plate, NOT the blade. There is a knob to lossen and tighen the tension on the table plate and you can adjust the blade height by lowering the plate and vice versa.
Jun 20, 2011 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
I can no longer raise or lower the blade on my 10" sears table saw' model # 113.298032.
After some use the threads on the raising mechanism can become clogged with sawdust and resin.
UNPLUG the saw and look underneath up inside the box. there is a rod that runs from the wheel you turn to raise and lower the blade into the actual mechanism. Brush it clean and give it a good douse of WD40 to help clean it. That rod must turn freely so look for any obstructions that will prevent that from happening
Jan 18, 2011 | Craftsman 10" Table Saw
I cannot easily raise/lower my blade on my Craftsman 10 inch table. I've cleaned out the say thouroughly and nothing appears to be obstructing mechanism to raise/lower the blade, but yet, it takes two...
mine did the same and i sprayed WD-40 on the assemblys or large screws and keep working it until free. but, check things over because some had a lock so the blade wont move after the hieght is set.
Dec 19, 2010 | Craftsman 10" Table Saw
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Mar 27, 2010 | Makita 2703 10" Table Saw, Electric Brake
Need a owner manual for tradesman bench table saw model 8031
Mar 18, 2009 | Saws
Saws Logo
23 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
