Question about Frigidaire Washing Machines
Thumping and banging during the high speed spin cycle
During the high speed spin cycle there is a loud thumping and banging. The springs and feet are secure and the tub is not loose. The motor and belt are both working properly.
  • Frigidaire Master
  • 5,323 Answers
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Posted on Apr 01, 2015
catriver
  • 878 Answers
SOURCE: Banging during high speed spin cycle
Laco, drop the bottom front panel and see if all of the shocks are in tact on the tub assy. They just insert and lock by turning. If these are ok, check the back belt pulley. Sometimes one of the tines will split or crack and you will get this symptom. Catriver..post back.
Posted on Mar 04, 2007
  • 156 Answers
SOURCE: thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Posted on Feb 25, 2008
BNewberry
  • 93 Answers
SOURCE: 90 Series Top Load Washer shakes during spin cycle
The Guide Plate underneath is out of alignment,, You might have to call me on this one. The only reason I am sure of this is because when my delivery guys would deliver a direct drive washer such as your, sometimes when the machine is laid down to far on its side, it gets out of alignment. Easy fix,, Just hard to explain.
Posted on Mar 26, 2008
  • 92 Answers
SOURCE: Loud banging/thumping during spin cycle on my kenmore front load
this sounds like this could be the bearings,to check for this,open door and with yourhand lift the inner chrome drum and let it fall then lift again and if you feel a knocking sound and a lot of play in it then its the bearings,i know there should be movement in the drum but this will feel more of a knocking.
Posted on Jul 07, 2009
  • 38 Answers
SOURCE: Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Posted on Sep 27, 2009
What could be the cause of loud thumping during spin?
Sounds like one of the balancing springs either broke or came off.
Feb 02, 2016 | Speed Washing Machines
Loud banging noise during spin cycle
If you balanced the machine, the only other problem could be the load itself. Either the load is too great or if washing a single item its falling to one side, tilting the drum and when spinning it will thump. Try even lodes.
Jan 31, 2018 | Washing Machines
Thunping or banging noise during wash cycle may tag MVWC300VWo quiet during spin
You will need to pull the basket and check the drive block.
Here is a video to show you how to get to the drive block.
Dec 03, 2012 | Maytag Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Thumping sound when the water turns on or off? during a normal cold cycle, we especially hear it during the spin cycle. It's not the spinning action it's the water turning on or off that makes a pretty...
Sounds like you are experiencing "water hammering". When the water valve shuts off quickly, the water which was flowing in the pipe must stop, and the momentum of the water suddenly stopping can cause the pipes to rattle or bang. Adding an air chamber would cusion that, and eliminate the banging. I have seen some (at a local Home Depot) which can screw onto the hose right where it connects to the hosehold shut off valve behind the washer.
Feb 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Jul 06, 2009 | Washing Machines
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
