Question about Verbatim 1TB USB2.0 HDD USB 2.0 Hard Drive
Is not recognized by computer
External hard drive with number 47512 is not recognized by computer
5 Suggested Answers
Crankstart
  • 696 Answers
SOURCE: My computer won't recognize the external hard drive.
The bad news is he's mostly right, not much the average user or lazy technician can do.
The good news is if you handy there's a cheap solution you can attempt, and if it fails several escalating levels of professional assistance you can get.
First, if you're feeling handy and want to try this yourself you can remove the HDD which will be a standard 2.5" or 3.5" harddrive(measure the narrow side).
Second, remove the cables and unscrew any mounting brackets.
If the cables are similar sizes and smooth resembling a USB cable they are SATA Cables and it is a SATA drive.
If one has four cables, usually one red, one yellow and two black and the other is a much wider wafer cable with either 40 or 80 pins it is an IDE drive(which type is of utmost importance in the next step).
Now, go to a computer store, or parts store(no staples doesn't count). Ask for a 2.5/3.5" SATA/IDE hard drive enclosure. I will be an empty shell similar to the one you just took apart.(should cost 20-50 depending on brand and store, I like nexstars myself but brand is not that important).
Take it home and assemble it with your drive inside. Power it up and plug in the USB.
If it works you HDD is likely fine and just the controller board has failed in the other enclosure. If it doesn't you're only out a few bucks and now you know for sure the problem is with the HDD and you will likely require further, direct assistance from a pro like myself.
Either way get back to me and I can bump you along to the next step or pat you on the back for a job well done
Hope this helps FixYa,
Chris
Armor-IT
Posted on Apr 26, 2009
lock123
  • 6831 Answers
SOURCE: I have an external hard drive back up, Verbatim,
Hello
A few questions that may confirm problem.
Does your computer seem to know that something is plugged in?
Or does it say that it does not recognize the device?
Well, if the computer actually knows that a device has been plugged in, but you just cannot see the device in my computer, here is how you fix that. Just follow these steps:
Control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your device presented in the schematic below.
Right click on the device and assign a new drive letter.
If your computer states that it does not recognize the device, try plugging it in one of the back USB ports of the computer. Please rate this.
Best regards
Posted on Sep 29, 2009
  • 215 Answers
SOURCE: My Verbatim external hard drive is not recognized
Is the new cable USB 2.0? Not all cables are equal. There are some cables with the correct connectors that do not even have the data wires passed through. they are described as charging cables.
It may sound foolish to ask, but is the power supply connected to the drive, plugged into power and switched on? You may not have disconnected it, but someone else or the cat may have.
Is there a switch on the drive casing?
Can you check the power supply and see if it is supplying 12 volts?
If none of this works, you could open up the case and remove the drive.
You could obtain a external drive case, and try it in that. That would give you a new cable and power supply so if the drive is ok, you should be able to access it.
It will almost certainly be a sata drive.
Posted on Feb 01, 2011
  • 239 Answers
SOURCE: Hi, my external hard drive starts clicking, when
If a hard drives starts clicking it would indicate that the heads are not functioning correctly and the drive is near or at the end of its useful life. It may be possible to recover the data from it but it depends on getting the computer to recognise the drive. I have heard of several 'tricks' but don't know about the effectiveness of them. These include wrapping the disk in a towel and sticking it in the freezer or using a throwing action similar to that you would use with a discus but obviously without letting go!
If you can take the actual drive from the casing you may be able to connect it directly to the computer using a special usb cable like this one
http://cgi.ebay.com/USB-2-0-SATA-IDE-Cable-Power-Adapter-Hard-Drive-/130492822544?pt=LH_DefaultDomain_2&hash=item1e61fa7410#ht_1928wt_1037
Please note I have no connection with the seller and the link is for illustration only.
Posted on Mar 02, 2011
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Dvd recorder hard drive not recognized when used as an external
Open Start menu
Click the right mouse button on Computer
On the pop out menu click on Manage
In the left hand menu click on Disk Manage
Your drive should show here if it is plugged in.
Delete all partitions
Now create a partition, format it how you want.
Mar 21, 2014 | Hitachi Computers & Internet
My Verbatim model #47512 1tb makes this beeping sound every time i connect it to my computer why?
That beeping signals a failure to communicate between the disk and the motherboard of the pc - the disk is defective. You have a slim chance of recovering what's on it by removing the actual disk from the external case and plugging it in the a desktop.
Jun 09, 2011 | Verbatim 1TB USB2.0 HDD USB 2.0 Hard Drive
My Verbatim Model #47512 1TB is showing as "Unknown" when connecting to the Computer. It was working earlier today but I removed it and then connected it again and now it's not working.. It's...
An external hard drive is a normal hard drive with a converter to change it to USB.
If you have important information on it, you could open it up, and connect internally to your computer, however, opening it will (almost always) void the warranty.
I'd recommend contacting whoever sold it to you, and asking them: 1) If you can open it up, to connect it internally, to get your data off, and 2) For a replacement.
Good luck with it.
Dec 22, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
I have a simpletech 250 GB external hard drive model number 96300-40001-001. I was transferring a file from my desktop to the external drive but canceled the operation because I didn't have time to wait....
May seem like a silly question you are not booting up computer with ext drive still plugged in are you?
i am assuming your operating system is on the internal drive.
if so don't have the external plugged in when you start up.
Dec 09, 2017 | SimpleTech SimpleDrive 250 GB External USB...
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
External Hard Drive malfunction
Hey Pete,
Why don't you try plugging it into another USB port?
Although, your best shot is going to verbatim.com/support/support-article.cfm?support_id=7B8B6B2C-1422-1392-A8B4CF52416BBF75&supportType=Article and follow that troubleshooting until the problem gets resolved.
Something that could really help us to help you, is if you are running windows XP or windows Vista.
Nov 25, 2008 | Computers & Internet
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Jul 31, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
Verbatim 1TB USB2.0 HDD USB 2.0 Hard Drive Logo
21 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
