Question about Yamaha P95 Digital Piano
Out of tune - Yamaha P95 Digital Piano
How do I set the tuner to tune at different keys?
Good question, tuners can be simple and some are complicated
a basic automatic guitar tuner you would not have to do anything to the settings, just tune normal on the E string then slowly down tune to D most tuners are a little sensitive, so go slow
and one thing I always do is go lower than the note I'm tuning to then tune up tell it's correct, strings seem to stay in tune better
Hope this helps ?
and if you have time check back on my profile
I will be doing some video tips this weekend
showing tuning, and some basic guitar repairs
thanks for your time
Mar 06, 2015 | Music
HOW DO I TUNE A KRAMER GUITAR
Without seeing your guitar, I'm going to assume the "tightening lugs" you're reffering to are the string locks on the nut. On a guitar with a "floyd rose" style tremolo system, the strings pass through a clamping system at the nut before going to the normal tuning keys. This clamping system "lugs" must be loosened then the guitar is tuned as it normally would, then the lugs are tightened to lock the strings in place. These clamps are not part of the tuning mechanism, but instead lock down the strings after they have been tuned by the keys. After all that, one would fine tune the guitar at the bridge rather than at the keys. A more complete explaination is found here-
String Tuning Instructions
Feb 17, 2015 | Kramer Music
Violin doesn't stay tuned
This is an intonation issue. If you can find a music store that works with violins, talk to someone there who will certainly be better informed than I am. At least they can tell you if it's worth your time to fix it, or more cost effective to replace it.
Apr 16, 2017 | Music
Tuner Won't Acknowledge Sound
Before turning the unit on, press the calib/batt button to check the battery condition.
The Fender AG6 only responds when the strings pitch is within a certain frequency range. If the guitars tuning is not within that range or if your installing new strings, first connect the guitar to the AG6 with a cord that you know to be in good working condition and turn the AG6 on. Then starting with the low E string (the thickest one), loosen the tuning peg to a point well below the standard tuning for that string. Then slowly tighten the peg as you strike the string repeatedly. When the strings frequency, comes within range you will see the 6E light glow and the needle will begin to deflect. When the needle reaches zero it is in tune. Do the remainder of the strings the same way then go back and recheck each a second time. If you have a tuning fork, you can use it to tune by ear then re-tune and maintain it with the AG6
Remember to always stretch then re-tune new strings several times.
If the AG6 does not respond even after checking the condition of the battery and the cord that connects the guitar to the tuner, the problem could be inside the AG6 with a bad connection on the board. Try moving the cord as you strike a string that you know is close to being in tune. Again a tuning fork would be helpful.
~DrewWatk
Jun 10, 2013 | Fender AG6 Automatic Guitar Tuner
KOrg X5D is out of tune
Did you try to get to Global mode, and then check if the tune is 440 hz?
Check the Global Settings. The tuning might either be altered or the key transposed..
May 05, 2013 | Korg X5d
Can't get the guitar tuned
Tell her to tune all strings below the pitch and always go up to the pitch, never down because of slack in the tuning keys. The gears will have a slight bit of play in them. If coming down and stopping at the right place, they will loosen and loose tuning when she lets go. Tuning from below and go up to the pitch will correct that. (more noticeable on electric) Also, I would take it to a shop to have the intonation checked and tuned if necessary.
Dec 25, 2012 | Schecter C-1 Classic Electric Guitar...
Is he tuner supposed to light up green when the string is correctly tuned?
Before turning the unit on, press and hold down the calib/batt switch to check the condition of the battery on the battery meter.
Then either plug in your electric guitar to the input side of the AG-6 or if tuning an acoustic guitar without electronics placing the AG-6 near the front of the guitar should work. You will not need to press a button to select which string you are about to tune. The AG-6 will detect it and the corresponding light will turn on when it is tuned within range.
Turn on the AG-6 and start by striking the low E (thickest) string while open. This is the number 6 string or 6E. Slowly turn the guitars low E tuning key untill the red LED below the 6E marking on the AG-6 lights up. Continue stricking the open string and turning the key untill the needle centers on zero and the 6E light remains on.
Repeat this for the open A string untill the 5A light turns on and the needle centers on zero.
Repeat for the remaining four strings, 4D 3G 2B and 1E, being careful not to over tighten and break them.
Tip: It may be a good idea once the low E string is tuned, to tune the rest manually, especially new strings or strings way out of tune. Then tune again using the AG-6 tuner.
If installing fresh strings you will probably need to stretch each string and re-tune, possibly several times, before they hold their tuning.
Feb 19, 2011 | Fender AG6 Automatic Guitar Tuner
How to tune?
the standard tuning is e a d g b e .go to www.fretjam.com/online-guitar-tuner.html. they have about everything you need on tuning and alternate tunings.
Dec 29, 2009 | Washburn D10sbc Acoustic Guitar
Tuning
If you are marginally interested in the process of tuning the piano, and your main motivation is to save the cost of a professional tuning, bite the bullet and engage the services of a qualified tuner. Trying to do it yourself will become overwhelming very quickly. If, however, you are genuinely interested in the skill of tuning, and willing to invest the time and effort to become good at it, then get yourself a star tipped tuning hammer and some mutes (eBay will do) and start to see what you can do to make your piano sound better. Begin by getting the whine out of individual notes by tuning the strings to each other. Search out the "Every which way you can" tuning article by Kent Swafford on your favorite search engine for an introduction to aural tuning. If you're inclined to start out with an electronic tuning aid, check out Tunelab Pro - a free, fully functional demo is available for download to your laptop. Remember, however, that an electronic aid only shows you whether you've hit your target for any given string. Learning how to finess the physical motions of tuning so that the string stays on target for more than a few minutes is another process altogether. If your first couple of forays into trying to tune don't drive you around the bend, then consider finding a qualified piano technician who would be willing to provide lessons for a fee. If your interest holds up, investigate the resources for learning that are available through the Piano Technicians Guild. Their source books and monthly journals are second to none, but unless you are committed enough to the process to become an associate member, the non-member prices for materials are pretty high. "Piano Servicing" by Reblitz is another excellent source of knowledge. It might be in your local library.
Mar 15, 2009 | Music
How can i tune my electric guitar
You can go to YouTube where people have videos of guitars of various tunings.
Here's one for standards tuning.
and here's one for Eflat tuning - Use this for Guns N Roses
Here's another way - Harmonic tuning - very cool
Aug 17, 2008 | Fender Fm25dsp 1x10' Guitar Combo...
Yamaha P95 Digital Piano Logo
41 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
