Question about Alpine CDA-9883 CD Player
Aux is working but when you turn it to radio no sound will come out
I turned the aux function on on my alpine cdm 9821 unit. I purchased an audio adapter with a red and white plug (to plug in the back of the reciever) on one side and a regular 3.5mm headphone jack on the...
You must make sure where you plug in on the radio side is Aux input, most Radio Aux is at the front or come with special connector if it is at the back. Mostly radio back come with RCA is for Line out not Aux in.
Nov 28, 2013 | Car Audio & Video
Radio and CD player in Jeep not working only Aux. Can only adjust volume when in Aux mode?
sounds like you might need a new cd player, if it was a fuse the problem would be there 100% of the time
Aug 11, 2012 | Jeep 2007 Grand Cherokee Laredo
I have a Bose Wave II radio. Never a problem until today. No sound from radio, CD, aux. Display works fine. Remote works. Have tried unplugging and plugging back in. Tried turning volume up, muting and...
in your boss amplifire system hardware problem in u try to mute and volume button please check aux port also if found no output sound then go boss service station there are some hardware problem
May 16, 2012 | Bose Audio Players & Recorders
I have a 2008 Harley D Street Glide with factory radio. Recently, while listening to the radio, the sound will stop emitting (power remains on). The loss of sound is prevelent with Aux, XM, FM & AM (in...
The internal amp is not getting a turn on signal from the audio processor. By cycling the radio off/on, the processor resets.
www.ironcrossaudio for repair options
Jun 29, 2011 | Harley Davidson 426290 AM/FM Radio
No volume
There are two ways to turn up the volume.
First the mp3 player has the volume dial turn that up all the way
Second there is a volume knob on the dewalt radio it is the black knob on top of radio on the right.
If those two knobs are unsuccessful make sure radio is on AUX there is a button on front right above the two arrows on front of the radio push that button until it says AUX that might be the reason your not getting sound
Oct 31, 2009 | SanDisk Sansa Fuse MP3 Player
Aux in runs only back speakers and no volume control
check sub setting some radios can select between non fading sub output or aux input
May 08, 2009 | Pioneer DEH-P3000 CD Player
My radio wont turn on
sound like you have a bad fuse in your aux wire check to make sure your aux wire has power when ignition is on if not check your fuses in your car start with the radio but it could be drawing from another fuse like cigar lighter good luck.....
Dec 31, 2008 | Clarion DXZ865MP CD Player
Aux wont work
Make sure that "AUX" is turned on on the menu. Some Pioneer radios have a front aux, a rear aux, a rear steering wheel control jack, and an aux through the IP-BUS only. First, make sure that if there is an auxillary port on the back of the unit, that it isn't the steering wheel control plug by accident. Second, front auxillary inputs on Pioneer radios NEVER need to be turned on in the menu, only inputs on the back. Any back inputs are turned on in the main set-up menu when the radio is first turned off. Hope this info helps.
Aug 22, 2008 | Pioneer Audio Players & Recorders
No Sound when AUX is on the screen...HELP
I'm having the same problem. Have you found a solution?
Aug 16, 2008 | Panasonic Home Theater System System
Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Mar 27, 2008 | Alpine CDA-7876RB CD Player
Alpine CDA-9883 CD Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
