Question about Sennheiser PC 330 Game Headphones
Sennheiser PC 330 Game audio works but not the mic
Brand new out of the box
2 Suggested Answers
SOURCE: Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
Posted on Dec 17, 2009
Sennheiser md 42 microphone not being picked up on camcorder help please.
This would require a special cable to work. The mic is MONOAURAL with BALANCED output and the camera is STEREO input. This means a special cable is needed and you would probably have to make it yourself as I haven't seen one on the market.Pin 2 of the XLR of the mic would go to BOTH the tip and ring of the plug into the camera. Both pins 1 and 3 of the XLR at the mic would tie to the sleeve of the plug to the camera. If you tried an XLR to 1/8 adapter, no audio would be heard other than from the buillt in mic.
Mar 08, 2013 | Sennheiser MD 42 Professional Microphone
How should I connect an ATM73a headset to a sennheiser SK300
Audio Technica and Sennheiser each have proprietary connectors for their mics. A lot of times the mics require Phantom power which is drawn from the battery of the pack.This is important as the mic will need to be wired correctly to function.
The first thing you will need is the correct plug from the company. Check with Sennheiser customer Support for the correct part. If you aren't extremely good at soldering, do not attempt this. You can change the plug but the wires are extremely delicate and can short easily. Moreover because of the phantom power, the plug must be wired correctly for the mic to function, or you may end up damaging the mic by sending phantom power up the wrong line. I would advise having a music store or pro audio service that handles these products do the wiring for you. If you feel you are up to it, you can do it yourself, but be careful.
Feb 19, 2011 | Sennheiser SK 300 G2 Wireless Bodypack...
My school uses Sennheiser Mic's for it's PA system. Is there an adaptor that would let me connect my CD player to the PA sytem's mic jack via the CD player's 3.5 mm headphone outlet?
The CD is STEREO whereas the MIC is monaural.
One could make an adapter that merges the left and right channels before sending on the balanced XLR input. This involves using an audio transformer or direct input box for the balanced line and is not DIY unless you are elctronically skilled.
The best way to do this is to instead plug the output of the CD into the TAPE inputs that are usually available on the mixer.
One uses usually a 3.5mm stereo splitter cable with RCA plugs for most of them.
Sep 10, 2010 | Sennheiser Epack-835 Professional...
Tanks
Nov 24, 2009 | Sennheiser RS 140 Consumer Headphones
Microphone too quiet
That's probably not going to work.
Mic level is extremely low compared with line level.
Your sound card is expecting a line level input.
It's simply not made to plug a microphone into (you must be using an adapter or two just to make the connection)
Look for a USB Audio Interface with XLR or 1/4" microphone inputs - these interfaces are pretty generic these days and easy to use ... just plug into your computer via USB and then plug the mic into the interface ... which has a volume control on it ...
I use a Tapco Link.USB ... and like it
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Oct 14, 2009 | Sennheiser E845S (3 Pack) Professional...
Sennheiser e835 wireless mic won't turn on
how long did you hold the on button for? press it longer
Mar 02, 2009 | Sennheiser E835 Professional Microphone
HELP
Audio Technica Part number 235401550, call 330-686-2600. The cost is $21.93, plus shipping
Jul 29, 2008 | Audio Technica ATW-T52 Professional...
Mokrophone is not working
Found the problem... What Apple has is a line-in port...it requires a pre-amp to boost the signal of your mic. A PC likely has a mic-in port.
They're different ports...very similar but they accept different levels of input. Apple likely wants you to use their built-in mic for mic use and the line-in port for line-level audio sources.
Thsi appears to be our solution... Griffin iMic / USB Audio Interface
What a pain.
Oct 20, 2007 | Sennheiser BINAURAL HEADSET :unitsize...
E835 distortion
it is very good brand first try to get ride off humidity and wet by putting it with some rice in plastic box and leave it for a couple of days(rice absorb wet and humidity).if it is not working good change the mic capsule.
Oct 05, 2007 | Sennheiser E835 Professional Microphone
Open Questions:
Sennheiser PC 330 Game Headphones Logo
44 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Vito Vacirca Jr.
Gerhardus Stroebel
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
