Question about Frigidaire FFUS2613L Side by Side Refrigerator
Frigidaire LFUS2613 LFO constantly beeping - Frigidaire FFUS2613L Side by Side Refrigerator
  • Official Brand Answer
  • 4,342 Answers
Hello Jalei, thank you for allowing me to assist you!
When your refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging your appliance or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Best of luck!
Posted on Feb 11, 2014
Why wont my refrigerator run. Constantly beeps.
The beeping is typically a code. Is there an addition of a led flashing anywhere you can see?
Jun 15, 2014 | Frigidaire FFHS2313LM 22.6 cu. ft. Side By...
My frigidaire side by side model#GLHS37EHSB7 is making a constant beeping noise and the electronic temperature display isnt coming on. what could be causing this
Hi Julie, this is JK. Thank you for your recent post!
I see that your Frigidaire Refrigerator, GLHS37EHSB7, is constantly beeping but the electronic temperature display is not working. Generally, this could happen when you experience a power failure. I would strongly suggest that you either unplug or turn the circuit breaker off to the unit for about 30 minutes. Let the unit reset completely and try to use it as normal again. If this concern still continues, I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Hope this helps!
Mar 19, 2014 | Frigidaire Refrigerators
Model LFUS2613LFO. Why is it constantly beeping?
I appreciate your submission, friend!
I understand that your Frigidaire refrigerator is constantly beeping and will not shut off. I have located the parts schematic for that specific model and I have provided a link for you to view it. If you still need additional assistance I would recommend speaking with your manufacturer to help locate a professional technician. -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Anderson/5995606919.pdf
Feb 08, 2014 | Frigidaire Refrigerators
My child lock on my Frigidaire is constantly beeping... The door is not locked but it is beeping...
Hello Shelley, thank you for your inquiry!
I understand your Frigidaire is constantly beeping while they door is unlock, however do you have a range or microwave Frigidaire appliance? The serial tag for a range, which lists your model number, is typically located in the storage drawer, on the right side and the serial tag for a microwave is in the lower left corner as you open the door. With this information I can better address the issue at hand. Thank you!
Oct 22, 2013 | Frigidaire Over-the-Range Microwave
I have a Frigidaire Beverage Center Model FFBC46F5LS It was installed on Friday and worked fine until today (Sunday) where it has started to beep constantly. If I press the light button at the bottom of...
I recently purchased a Frigidaire Beverage Center and had the same constant beeping issue as strivieri. I found my problem to be the door sensor. The door sensor is located on the lower bottom right of the unit and there is a metal plate mounted on the swinging door that is suppose to push that sensor in when the door is closed. However, this was poorly designed as it fails to do its task. I had a few adhesive floor protectors laying around that I used to stick to that metal plate that gave it the extra thickness needed to push in the door sensor when closing the door.
I hope this helps anyone else there having the same issue.
Nov 14, 2010 | Frigidaire FFBC46F5LS
Control panel beeps constantly. Have to unplug to get it to stop. Once it's plugged in it will begin beeping again within 30 min.
Hello- The control is not happy. Depending upon the number of 'self-clean' cycles, control may have failed. Find a good tech to check it out. Replacement board w/overlay is about 200$. Let me know if this info helps- have more if needed. -Thanks- ED
Mar 06, 2010 | Frigidaire PLGFMZ98GC Kitchen Range
Constant beeping
I have an ATF8000 that did the same thing, unfortunately when this happens the entire control board must be replaced. I bought it for about $130 from a local appliance repair shop who then installed it for about $50. In all with tax it was near $200 repair.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FFUS2613L Side by Side Refrigerator Logo
207 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
