Question about Numark Industries NUMARK C3FX DJ MIXER
Hum in speakers using numark c3fx
Old mixing board went out,now using numark c3fx and get hum from speakers more so when effects are on
  • Numark Master
  • 1,931 Answers
Or an earth problem (connecting cable problem) or dirth in potentiometers or some leaking or bad capacitors
Posted on Jul 01, 2016
2 Suggested Answers
DIESELMUDDER
  • 2760 Answers
SOURCE: Im just wondering if there is a company that works on numark C3FX, main gain and channel 1234 are not working properly ,if i put the volume up It will go up with it for a few se
sure tons!!! most every music shop that I ever been in (and that's a lot !!) that sold instruments and stuff has either an in house tech or a "guy" they go to , ask em as they get perks for referrals
Posted on Jan 05, 2016
Jan 05, 2016 | Numark Music
Hi i have an Allen and Heath ZED 22 with no onboard effects. I would like to use an external Behringher unit but am having difficulty in connecting the processed signal back to the mixer. i would like to...
Send audio from board via the "Aux1 Out" to the input of the effects unit. Now connect the output of the effects unit to "ST1" and control the amount of effects to each channel via each channels "Aux1" control. Adjust the Aux1 controls in the output stage (controls on the right side) for proper levels.
Older boards called this connection "effects send" for the output to the effect, and "effects return" for the effects out back to the board. The better choice was to use "effects send" into the effect but connect the effects output to an unused channel on the board. Using this scenario allowed EQ adjustments to be made before mixing it out to the amps and speakers.
Oct 01, 2013 | Peavey XR 8600D Powered Mixer
My numark NDX400 is acting strange. When i am
i did have same problem,i sale them in secend hand shope,not trsutfull ndx400 to be honest.after that i buye new numark mix express.that better than ndx400
Aug 03, 2013 | Numark Industries Numark NDX400 Tabletop...
How do i record from numark icd mix 3
you need to get a burner..........preferably sony cd recorder
Jan 04, 2013 | Numark Industries Numark iCDMIX 3 Dual...
I HAVE A NUMARKKMX01 MIXER WHEN I PLUG THE RED RCA JACK IN TO THE MIXER I GET A LOUND HUM
What is plugged into your Numark mixer when this happens? Try disconnecting ALL audio inputs to your mixer, turn mixer volumes to zero and see if the hum is still present. Adjust the volume and check if the hum you mentioned returns. If it is still heard, try new cables between the mixer and amp...if not then start reconnecting inputs until the hum is heard again. It's a process of elimination but not that difficult to find the source of your problem.
Oct 31, 2012 | Numark Industries Numark DM 1200 Mixer
Mixing board hum
AC hum comes from poor grounding of components.
Jun 21, 2017 | Music
Our mixture MACKIE CFX 20 give a humming sound as the clip light always on, but this does not happen before, tell me how to stop this
You say the clip light is always on, as the only clip lights on this mixer are on the effects channel and the master output and you do not say which is on there are a number of possibilities. You may have the effects turned up too far as this should not be showing, just maybe blinking, turn them down on efx2 on all strips as well as on the effects processor and see if this helps. If it does you may be able to find where the hum is coming from by gradually increasing each until you find it.
If you are getting the clip on the main mix master and you are not being deafened and the humming sound is coming from the speakers not the mixer you may have a subsonic signal getting into the mixer. Disconnect all inputs and if this cures it go through until you find where it is getting in and sort that.
If the humming is coming from the mixer it is possible that the smoothing caps on the PSU are dying, you do not say if you are getting normal sound as well as the humming from the mixer.
When asking for help please try to give as much information as possible
Sep 27, 2012 | Mackie cfx20 mkII compact mixer
I've connect my sampler to the mixer. In the RCA "send" and it won't play through my speakers. I can only hear it through the headphones. What could be the problem? I'm using Numark...
You would NOT connect an audio signal to the "send" jacks... those are OUTPUTS... In doing so you are driving signal backward enough to get to the headphones. Sends and returns are NORMALLY used on a mixer for external effects. You should either be using a LINE input jack or one for "tape input".
Sep 10, 2011 | Roland Sp404sx Portable Sampler Wdsp...
Do you have a FAQ section, just so that I can review what others have experienced. I have 2 Mix3's using powered JBL speakers without any problems. But I am thinking of switching out the powered...
No problems doing this. Just make sure to power the amp and the Mix 3 from the same receptacle or power conditioner. Remember IF you are using the EQ functions of powered speakers you will NOT have those when going directely to an amp.
May 08, 2011 | Numark Industries Numark CD Mix 3
Numark Industries NUMARK C3FX DJ MIXER Logo
42 people viewed this question
Top Numark Music Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
rhodesworks
Seanzilla
Are you a Numark Music Expert? Answer questions, earn points and help others
