Question about Maytag MDE2400 Dryer
Maytag mde2400 thermostat replace
I have have the part, how do I get the old one out and put the new one in?
When running smell burning comes out
Replace the high limit thermostat. Here is the thermostat to order.
The thermostat is located to the top of the heater assembly.
Nov 12, 2012 | Maytag MDE2400 Dryer
I have a Magic Chef compact refrigerator model MCBR270 that now runs constantly and freezes everything I put in it no matter what setting is used on the temperature control knob. What can I do to diagnose...
Well, this answer is 6 years late.
I have the same model MC frig - 14 years old. There is only two electrical components; the compressor and the thermostat. Since the compressor is running and freezing, the thermostat must be stuck on. You need to replace the thermostat. My thermostat is also bad. I can't find one. One of the numbers on the thermostat is LR62862. Another is PFN-110U 02D. May be time for a new frig.
Feb 06, 2011 | Maytag Refrigerators
Replacing the heating coil on my MDE2400?
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
I am sure you will be able to find the new heating coil at one or both of these web sites
I will include these two web sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck, Hope this helps
Please do not forget to rate me, Thank you
May 27, 2010 | Maytag MDE2400A Electric Dryer
How do I remove the front of my MDE 2400 dryer?
two clips one on each side located in the gap between the top and the front slide a knife into each clips maintaining a little positive upwards pressure top should rotateupwards being hinged in back
Aug 07, 2009 | Maytag MDE2400 Dryer
Magtag Dryer MDE2400 Dryer won't turn off
On our Maytag dryer, the looping marquee lights mean that the dryer is in "wrinkle" mode. This means that the wrinkle mode has been selected. In this mode, the dryer continues to rotate on and off after the heat cycle has ended. It does this to keep the clothes from wrinkling -- and it displays the looping lights.
Jul 24, 2009 | Maytag MDE2400A Electric Dryer
Maytag top freezer MTF2176hr melt down
Sounds like a bad cold control ( thermostat ) The switch that cuts the fridge off/on .
Jul 16, 2009 | Refrigerators
No heat from dryer
You have a bad heating element and or a bad high limit switch. Check them for continuity with a volt meter. No continuity, replace the part.
May 24, 2009 | Maytag MDE2400 Dryer
Two year old Maytag Fridge not cooling
pull the power plug for 15 minutes, then plug back in...same problem? tried adjusting temperature control knob (thermostat)? if yes to both questions, freon has escaped out of loop or faulty thermostat. Attempt force start of compressor with jumper clips: pull the power plug then find the two wires into motor and apply 120 VAC from jumper clips. If it spins, then faulty thermostat.
Jun 18, 2007 | Maytag MTB2656G Top Freezer Refrigerator
Maytag Dryer Tstat wiring
I believe that this part is a thermostat. If im not mistaken, it shouldnt matter which wire goes on which prong. Think this is a reversable thermostat. It should have just 2 prongs correct? Jim
Aug 31, 2006 | Maytag PYE2300AY Electric Dryer
Maytag MDE2400 Dryer Logo
23 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
