At Login the Message User Profile Not recognised is shown, and I cannot get past it, if I Log in as another Usewr and try to download any help from the Net, I get error messages there to, so cannot download any help....have seen many suggestions of how to sort out User Profile problem but cannot get far enough in to change anything! Help!
At log in get error message-User Profile Service service failed can not load user profile
Sounds like you might have deleted a system file or have malware infection. First try using f8 on black screen right after initial start screen but before windows starts to launch. This puts you into safe mode. Now try system tetore and go back to last known good restore point. Hopefully that works.
Jan 03, 2015 | Toshiba Satellite Computers & Internet
How can I fix my service failed to log on?
You will need to download EBCD software and follow the instructions.
Aug 27, 2014 | Computers & Internet
Toshiba mk6475gsx
Hi
If you have forgotten your password to log on to windows then you will not be able to log on to your profile as this needs your windows password.
If you have a sepreate administration account on the laptop you can log on with this make another user account to log on, log on with this account to create your new profile then log off, back on as admin, you should then have access to the users folder and with admin rights you should have access to copy your stuff from the old user profile to the new one.
Cliff Cook
MCP
Aug 02, 2014 | Toshiba Satellite Computers & Internet
Won't log in, says "the User Profile Service service failed the logon. User Profile cannot be loaded."
This is a simple fix that can be done in a few minutes or less. It is a problem with either an update from MSFT that had gone awry or an attack from a virus... Anyhow the steps to take are relatively simple just follow along.
1 - go to this site and it will walk you through step by step
You receive The User Profile Service failed the logon error message *make sure to choose option 1
Apr 12, 2014 | Computers & Internet
Won't login
when your netbook starts up, press f8 and from the following menu, choose to start using safe mode with gui. If you have specified an administrative password at the time of windows installation, use that to log on. If you have not, you should be able to simply log on with the administrative account. Now, go to the control panel>user accounts and create a new user account. Now, you should be able to logon using the new user account. Make this one an administrative/standard account instead of a limited one. When you logon using this account, you should be able to get your data of the previous account from C:\Users\<previous profile name>... You can take backup of this data and then delete the previous user profile to avoid further confusion.
Hope this helps.
Nov 19, 2013 | eMachines eM250-1915 Netbook
My laptop wont let me log on user profile service service failed to log on
U can try login in to the same user account in safe mode or try login in a different profile from there see if u can make any chages in the account of if the data there is intact. For further resolution u can visit this website.
Apr 25, 2010 | Sony Computers & Internet
User profile
better to login as administrator in the safe mode try modify the password and user profile , you can fix it. then restart the system login through the normal mode.
Feb 15, 2010 | Dell Inspiron 1545 Notebook
I cannot log on. i type in my password which is correct i get the following message 'the user profile service failed the log on' also 'user profile cannot be loaded' is there a way round this as i cannot...
Hi! with respect to your words, we can clear two concepts those are, you can't login since "user profile failed" and you are no more since "user profile cannot be loaded", so we need to think about new account. please consider to enter the system in general way and later try to have new account with out error and have fine
Dec 18, 2009 | Computers & Internet
System won't go past profile page..stuck
It seems that the Guest account profile is corrupted because of which you are unable to log in as like in previously.
In the Profile Login page, hold the Ctrl and Alt keys and press the Del key twice.
This will give you a window where you need to enter the User name and Password.
Enter the User name as administrator and leave the password column blank if you have not set any Password to the administrator account or enter the Administrator password if you have set any.
Now once you are loged into the Administrator account, create a new User from the Control Panel > User Accounts.
Set the required limitatios to the account like limited account or administrator account and log off from the administrator account.
Now, you should have the newly created user account available in the login page. Select it and you should be able to login.
Aug 11, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
David Payne
David Payne
