Question about Gateway FPD2275W LCD Monitor
Everything is plugged in but Gateway 500 G
Monitor dark
Monitor stays dark
Hi Don, If the monitor is showing that message it means that it is not getting a video signal from the computer.. Check that all of your connectors are fully plugged in and properly fastened. Restart the computer and see what happens. If you still get the message they replace the video cable and try again. If the result is still the samew then you either have a problem at the monitor or, more likely as your other monitor didn't work, a problem with the video card in the computer.
Mar 12, 2013 | Gateway Computers & Internet
Gateway laptop p-6822; possible inverter problems - dark screen on bootup?
Does it matter if the computer is plugged in or on battery? If its the same either way, yes most likely its either the inverter or "backlight". A good way to test is , plug it in the and external monitor and see how the picture is.
Jan 02, 2011 | Gateway Computers & Internet
I have a Gateway FPD 1530 Monitor. Both of the lamps in the screen will light up for about a second, then go off. I used a flashlight to check the screen in a dark room. You can still see the desktop in...
Be careful with that meter, you may destroy the input circuits of the meter. The starting voltage to fire up the lamp is about 1500~2000vac!, maintain on state is about 500~800v.
How do the caps look on the board?
Please lear more here:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 10, 2010 | Gateway Computers & Internet
Gateway sheild theft mode display and everythings blk+white
The problem was repaired by, Calling gateway. You pull up the challange code #'s on the monitor. You tell gateway agent the code numbers, they tell you a unlock code. You enter that on your monitor. and thats that! You pull up the challange code by unpluging your monitor then hold the menu button on monitor. plug back in holding the menu button! larrygl.
Jan 26, 2009 | Hyundai L90D+ 19" LCD Monitor
No signal on monitor
You probably have 2 monitor connections. you have a standard one, and one that is through a graphics card at the bottom of your tower. Check for that second connection and switch the plug.. that should solve it.
Jan 02, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway 320S monitor is dark... external monitor works fine
Yes your back light has failed inside the lcd. That can be replaced.
Oct 28, 2008 | Gateway M305CRV Notebook
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
Gateway 3522GZ display
Some searching on forums convinced me the inverter had failed. Picked one up for $65, removed the frame around the screen, removed the mounting screw for the inverter, and unplugged both ends of the old and plugged in the new. Put it back togeher and fired it up, bright again. Key here was that a remote monitor still worked which meant video card was OK. The lamp could have been bad, but apparently the life of lamps is pretty decent.
Aug 31, 2008 | Gateway 3522GZ Notebook
Gateway FPD2275W LCD Monitor Logo
15 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
