Question about Star Natural Gas Max 630FF 30 lb. Gas Countertop Fryer - 70,000 BTU
Pilot light will not stay lit on a star 630 FF fryer
Pilot light goes out when you release the button. It is not the high limit switch
4 Suggested Answers
bigg t
  • 640 Answers
SOURCE: star deep fryer.
Those thermostat bulbs are the thermostat and hi-limit bulbs.They need to be secured to the fryer.The hi limit is tripping out because its sensing that the oil is too hot.Even though the oil isnt that hot the hi limit thinks it is.
Posted on May 30, 2008
burzerko
  • 254 Answers
SOURCE: fryer quits heating have to hit reset switch
This button should be a high limit switch. If it is a small red button mounted to a 2" x 2" or so device. You most likley have an issue with the thermostat letting it over heat. The best thing to do would be to replace both the thermostat and the high limit for safety reasons.
Posted on Jun 17, 2008
  • 3238 Answers
SOURCE: pilot does not stay lit
clean pilot light first , you may need to change thermopile or thermocouple see what mille volts you get from thermopile need 600mille volts
Posted on Apr 01, 2012
When I light my Pilot on my Fryer it will not stay lit long enough to light the fryer. What can i do?
There are several possible causes of this problem, aside from a loose or damaged wire, which is uncommon. The cause in about 95% of the cases is a thermopile that has gone bad. The thermopile is the small cylinder that is attached to the pilot assembly where part of the pilot flame can contact it. It has a cable or wire going to the gas valve, high limit switch, or both. When hot enough, it produces and electrical current that keep the pilot on and allows the main gas valve to open. This is not hard to replace in most gas fryers and not too expensive. This often starts as an intermittent problem. The second possible cause is a defective high limit. The high limit is a small rectangular device with wires going to the gas valve and a tiny stainless tube that goes through the bottom of the kettle to a sensor bulb, like the thermostat has. These are usually self resetting, but may have a small red reset button. If present check the reset. If no reset, jump the two wires and see if the fryer will now light. If so, the high limit is defective, assuming the fryer is not over temperature. If defective, replace. Do not operate the fryer in this condition as there is no over temperature protection. The next cause is if the oil is too hot, in which case the high limit will shut off both the main burner and the pilot. The pilot cannot be relit until the fryer cools down and the high limit resets. If the oil is too hot, usually over 425F, replace the thermostat. If the high limit trips when the oil is in the normal operating range, replace the high limit. The final cause is a bad gas valve. This is not too common, but the gas valve is expensive and a bit difficult to replace. Check all of the other causes first.
Sep 22, 2014 | Kitchen Appliances - Others
Pilot wont stay lit falcon dominator fryer
Sep 19, 2014 | Kitchen Appliances - Others
Nearest engineer to Stamford
Sep 16, 2014 | Pitco Frialator Kitchen Appliances -...
I have got lincat fryer j10 the pilot won't stay
Hi there.
Make sure that the thermopile is receiving enough heat from the pilot and if it does, check if the hi limit is good, check and tighten also all of the wiring connections, before replacing the gas valve.
Regards.
Jun 11, 2013 | Kitchen Appliances - Others
Pilot light won't stay lit after releasing when lighting gas fryer
This symptom indicates something wrong with the millivolt system. Start by checking the wires from the thermopile to the gas valve, insuring they are all tight and in place. Check the hi limit thermostat, if you have an ohm meter it should read .1 or .2 across it. With you meter set to dc millivolts, and flame present on the pilot, read across the thermocouple wires (red and white) to see the millivolts generated, with the thermostat off and the gas valve in pilot position you should get approx 600 millivolt plus minus 50. The pilot will have to be on for a minute or so to get maximum millivolts. If the millivolts are correct, hi-limit closed, and all wiring is connected, you likely have a faulty gas valve. If the hi limit reads more than .1 or .2 replace the limit, if you are not getting the millivolts from the thermopile, replace it.
Apr 05, 2013 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Pilot light goes out when i let off the button. ive replaaced the valve and thermopile. i was told it could be the hi limit switch does that make sense?
Yes it does. The high limit is a safety device on all fryers. For your fryer it is mounted on the right side inside the door. Push in on the red stem sticking out of the front of it. If it is tripped you will hear a click when you push it and then the pilot will probably stay lit. If it is a case of the high limit tripped....then you need to check your thermostat and make sure that it cycles the main burners off at the set temperature.
Jan 16, 2010 | Imperial IFS40 Deep Fryer
Pilot wont stay lit
If it will not stay lit from a cold start, you will need a thermopile. You can check it if you have a DC meter that will test milivolts. It should be putting out between 300 and 500. If it will not stay lit after the pot gets hot, you will most likely need a high limit. Try pushing the red button below the thermostat. This will reset the high limit.
Oct 04, 2009 | Pitco Frialator 45C Deep Fryer
Imperial propane fryer won't stay lit.
check the high limit it tripping out
May 22, 2009 | Imperial IFS40 Deep Fryer
Imperial fryer
Try to clean the pilot orfice,ive seen even though the pilot stays lit it doesnt have enough millivolts to energize the gas valve.Did you check the wiring really good?
Feb 08, 2009 | Imperial IFS40 Deep Fryer
You can not check a thermocouple by resistence. You have to check it by millivoltage when it is hot and sensing it should be above 500mv. I would be willing to bet that you have some type of particulate in the gas valve that is causing this problem.
Jun 23, 2008 | Pitco Frialator SG14 Deep Fryer
Star Natural Gas Max 630FF 30 lb. Gas Countertop Fryer - 70,000 BTU Logo
27 people viewed this question
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Bill Boyd
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
