Question about Creative Technology Creative Labs D200 Wireless Portable Bluetooth Speakers Speaker System
My speaker use to connect to my IPad just fine. The light on top would be blue when it was connected. Now when I try to connect it, it gives me a solid yellow light and the connection is unsuccessful. Is there a way to reset the speaker?
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: I just bought the Creative T40 II series speakers.
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Posted on Feb 21, 2011
Cannot establish blue tooth connection to ipad
try to turn on BT on iPad while Logitech is blinking (which means it in pairing mode and can be discovered). If that doesn't help I'd suggest to remove batteries from Logitech for 3-5 minutes then put them back.
Feb 08, 2015 | Logitech Ultrathin Keyboard Cover
How do I pair my I Pad with my new Philips portable speaker using bluetooth ( can connect fine using a cable)
If your portable speaker is Bluetooth-enabled, here is the general procedure:
1. Press and hold the function control button on the speaker until you see red and blue lights flashing in rapid succession on the speaker (the speaker is now in "pairing" mode).
2. Turn on Bluetooth on your iPad and then tap on Scan. iPad will begin scanning for nearby Bluetooth devices. When you see a name similar to that of your speaker, tap on it . You will be asked for a passcode/passkey to pair the iPad with the speaker. Enter '0000' or '1234' (without the quotes).
3. Once the passkey is accepted, the two devices are now paired. The light on the speaker should become a steady blue.
4. On the iPad, tap on Connect. If the iPad connects to the speaker, you will see Connected. You are done. Play some music from the iPad to see if you can hear it coming through the speaker.
You should have this procedure detailed in the set up guide that came with the speaker. Please note that pairing is required only for the first time you try to connect the two devices, to get them "acquainted" to each other. After that, all you need is to connect the iPad to the speaker every time you want to listen to your iPad through the speaker.
Nov 30, 2014 | Philips Audio Players & Recorders
How to recover my disabled ipad
It would be easy, to connect it to a PC with iTunes on it. But still to get it work, I think you have to give in your password for the Apple ID this iPad is connected to.
If it is really going bad, please look on the link:
How to Reset Forgotten Password for an iOS Device
Sep 16, 2014 | Philips Ipad Mac Airplay Wi-fi Wireless...
How to get bluetooth speaker to connect already apired and is showing but wont connect
Hello, I have already met this issue: after pairing a bluetooth speaker on a first host (computer or iPad), then pairing it on a second device (as another computer for example), when I try to pair it again to its original host device, it doesn't work.
The solution consist in
1) on the host computer, in the list of the Bluetooth devices, delete the line of the bluetooth speaker and forget this bluetooth device,
2) push on the Bluetooth detect button on Bluetooth speaker,
3) scan the bluetooth devices on your computer host, and when you see the bluetooth speaker in the list, select it.
Jul 28, 2014 | Toshiba Satellite Laptop with AMD Athlon...
Big blue won't pair with iPad even though the iPad shows it's discoverable. Also, when I connect speaker it ipod using cable, it beeps but won't play.
That's because the speakers are broken. Look in the User guide for reset instructions. If that doesn't work buy new speakers.
Apr 21, 2014 | Brookstone Big Blue Live Wireless...
Manually reset convertible top
basically the unit is recognizing the analog signal but not the digital signal.. may need a converter..
Jan 20, 2014 | Sherwood Audio Players & Recorders
Isound will not connect
Just hold the Bluetooth bottom while trying to connect to phone
Nov 28, 2013 | iSOUND 1690 TWIST WIRELESS SPEAKER &...
I have a JBL wireless flip speaker and even after reading the so-called manual, I have absolutely NO idea how to use it . My iPad has blue tooth capability but,I,don,t even know what,exactly is Bluetooth...
Once you put the JBL speaker on, turn on bluetooth on your ipad, search for bluetooth device, it takes a few minutes sometime to locate your speaker, once you see your speaker listed in the bluetooth device, click on the device. IT will connect but at times it might ask for a PIN.
Oct 01, 2013 | Radio Communications
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Jan 14, 2013 | Harman Kardon JBL Flip black
How do i connect my ipad to the hello kitty keyboard
After turning on your keyboard, the blue indicator light will come on for a couple of seconds, then go away. Next, press the button that says "connect" at the very top right corner of the keyboard. It looks like a wifi signal with a circle around it (I had trouble with this part, I didn't realize it was a button). Blue indicator light will start blinking, meaning that it's ready to connect. Go to Settings > Bluetooth (make sure it's on) > click on device. Voila!
Nov 29, 2012 | Hello Kitty Portfolio Case and Bluetooth...
Creative Technology Creative Labs D200 Wireless Portable Bluetooth Speakers Speaker System Logo
26 people viewed this question
Top Creative Technology Audio Players & Recorders Experts
Jim Y
Jim Y
elvis nunex
Level 1 Expert
Tom Chichester
Are you a Creative Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
