Question about Electrolux Washing Machines
Detergent drawer won't open on electrolux washer
The spring loading assembly has fallen out
maklean
  • 1665 Answers
SOURCE: detergent dispenser stuck, I think the detergent cup is preventing the drawer from opening
Here there is a user guide and instructions of a similar washer model.
http://www.laundrymanuals.com/manuals/mfg/lg/wm2496h.html
and also all available LG washer manuals to download.
http://www.laundrymanuals.com/manuals/mfg/lg/lg_frontload_washer_product_list.html
Have a look of how top lid is mounted.
Posted on Feb 15, 2008
MNTECH
  • 1543 Answers
SOURCE: Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Posted on Oct 11, 2008
SOURCE: front loader LG washer drawer for detergent is stuck won't open
Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
Posted on Jun 16, 2009
SOURCE: Bosch Axxis Washer Detergent slot codes; what do they mean?
soap goes in far left
softner middle
liquid all fabric bleach or powder bleach in far right
Posted on Jun 24, 2009
SOURCE: water is pouring out of my dispenser drawer
I have read other folks say that this has happened to them when a sock or wash cloth gets stuck behind the rubber seal of the door. There is a pipe that drains the water from your detergent tray and it may be clogged with a sock. Try feeling around behind the rubber seal in proximity to the detergent tray and see if there is a piece of clothing stuck in the pipe that drains the detergent tray. Also remove the tray and check the pipe from that end too.
Posted on May 04, 2010
Testimonial: "Thank you I took the tray out and checked. I did not find anything so I poured hot water in the tray with some bakingsoda and vinegar.. it fizzed and then 10 mins later... it drained.."
The door on the inside of my projector in front of the slide wont open when a slide is in ???
The shutter ("door" you refer to) should be spring loaded - the spring will snap the door open when a slide enters the gate. Usually, if the shutter fails to open, it is because the spring that tensions the shutter has either fallen off or somehow unhooked.
Sep 23, 2014 | Kodak Carousel 4600 Slide Projector
Detergent drawer keeps opening
check you have your washing machine level even slightly tilt in front
Feb 09, 2014 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux frontloader washer detergent drawer won't stay shut
Hello royal37 - Hi - The dispenser drawer could either be cracked or have a broken latch due to interference between the drawer front and top panel. Contact a professional to move forward accurately and might possibly need to order a service kit (PN: 137146000/part number may be different depending on your model number).
Feb 13, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Replace main drive belt on clark bobcat 873
It is is supposed to have a spring tensioner like the one on your daily driver.
The bushing may have worn enough for the idler to have fallen off the one you have. They would have been the bolts you kept getting the belt hung up on as you threaded the belt on the pulleys. If the spring itslef brokey you need the entire idler assembly.
Jan 06, 2012 | Welding Tools
Clip and spring fell out of wand
Hi Brian,
I'm sorry to hear about this - if the clip and spring have fallen out of the wand assembly, I'd encourage you to give our Helpline a call free on 1-866-693-9766 so we can provide assistance. If it's necessary to replace the wand, this should be covered by our 5-year guarantee, as long as the machine has been used in accordance with the terms and conditions listed in the user guide.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
Jan 02, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
Leaves detergent in despencer tray
Most of the time this is a dispenser housing issue. Remove the dispenser tray from washer and make sure it is cleaned very well. In the more serious clogs, you may need to clean the hose from the dispenser to the drum.
  1. Make sure the detergent dispenser drawer is opening. This issue occurs due to jammed soap dispenser. Dispenser Distribution System is located in the top left corner of the washer. The system consists of a motor that turns a cam gear. The Detergent Dispenser Assembly is located under the washer top. Begin by removing the washer top, console and front panel.
  2. Separate the water inlet and window washer tube from the boot. Pull the water inlet tube from the outlet connector of the detergent dispenser. NOTE: When reinstalling the water inlet tube, wet the water inlet gasket on the detergent dispenser with water only. Do not use any other lubricant. Align the tab on the water inlet tube with the indentation on the dispenser connector and slide the tube onto the detergent dispenser assembly.
  3. Remove the screw securing the front of the detergent dispenser assembly to the top front frame member.
  4. Disconnect the vent tube from the detergent dispenser assembly. Remove the screw securing the detergent dispenser assembly to the top left frame member. Slide the assembly back slightly and lift the assembly out.
  5. To remove the detergent dispenser motor assembly,disconnect the cam follower spring and lift the cam follower from the diverter cam and rotate the diverter cam clockwise to access the motor mounting screws. Check for all the connections to the dispenser motor or anything obstructing the dispenser drawer functioning.
  6. Pull the diverter out and clean it, including the shaft, spring, etc.
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When pushing the soap dispenser drawer it does not spring open any longer. Is there a way to fix this?
Re: Soap dispenser door not opening properly...(in case you still need to know)
You might want to use a small mirror (and flashlight) to see where the the spring assembly fits. Turn the rod facing towards you with the flat side up. It attaches at the rear, top left corner, near a small opening on the back wall (shaped liked the assembly). Fits into the "grooves". Apply enough pressure and you will feel it snap into place.
Dec 31, 2010 | Electrolux EIFLW55I Washer
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
94 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
