Question about GE Refrigerators
How do you replace a water filter on a ge fridge model number gfss6kkycss
4 Suggested Answers
  • 150 Answers
SOURCE: GE SmartWater Filter - Model MWF
make sure filter is installed correctly (not to doubt you but it can happen) make sure there isn't some foriegn object or packing materialetc in the filter end. You could have a bad filter. also make sure the unit is purged well
Posted on May 15, 2008
SOURCE: I replaced the water filter for my GE GSH25JSTA SS
I have had the same problem with the same model several times in the past. It also happens to me within a few days of replacing the water filter.
In my case, I believe the water line in the freezer door has become frozen. I usually let the freezer thaw for a couple of hours, and my water works again.
I have had constant problems with this model. I would recommend trying to sell your fridge now while it's still running, before the real headaches begin (mine has died 2x in the past six months, and I have not even had it for 2.5 years yet). No more GE's in my house.
Posted on Jul 20, 2009
SOURCE: Fridge Makes Cubes But No Water
Get part number WR49X10173 from Consumer Relations (800-386-1215. (Free; be sure they understand how long you have had to deal with this issue) ($38+ if you buy part on line)
The part includes instructions to install, but not how to remove the control panel. Here's how: Look from below the panel to observe 3 holes (aprox. 1/8" dia) located in a long narrow depression. Observe that there is the edged of a plactic tab visible partly covering each hole. Use a pointed tool such as a shish-kabob skewer to carefully probe the hole at the right or left end, and carefully pull the control panel forward on the side with the hole you are probing. This will help release the tab, allowing the panel to come off. Repeat for the opposite side.
The instructions with the part take over from here. The part is a loop of wire that provides a bit of heat to keep the area warm, and is held in place by some aluminum tape, then spliced into the red and the black/white wires on the 6-wire harness on the left side of the control. BE SURE the power is OFF!!!!
Posted on Dec 26, 2009
I have a GE refrigerator model gfss6kkycss with a Samsung ice maker model DA97-07365A the problem is it is not making any ice and the water dispenser is working fine
-Make sure turn the ice maker " ON"
If it's on then the Water valve to the ice maker might not function.
Good luck
Mai
Oct 26, 2017 | GE Refrigerators
WHERE IS THE WATER FILTER FOR GE MODEL GSS201EPHWW
bad model number,some machines don't have filters,they have in line filters ,usually found in basment,the cooper fill line that goes to fridge is cut and a filter is added into the fill line
Oct 09, 2014 | GE Refrigerators
Water dispenser and ice maker are not working, water supply to refrigerator is ok.
Check / replace the filter. Many fridges have a filter readily accessible from the fresh food compartment. The filter should be changed at regular intervals for best performance. A filter that is never changed will reduce and eventually stop water flow through it.
Check the temperature of the fresh food compartment near the filter. It may be "flirting" with the 32 degree mark. If it is this low, water has turned to ice - and will stop water from flowing. Bump the temperature up a tad to see if it solves the problem.
Lastly, the water supply solenoid may have failed. You didn't provide the model fridge - so I can't give specific info about it - but many fridges have one or two solenoids at the rear of the fridge for water supply and ice makers. You should hear a clicking sound from the rear of the fridge on many models when dispensing water or when the ice maker cycles on. If one has failed, you may expect to pay about $15 to $50 for a replacement - depending model.
Typical GE Refrigerator Single Solenoid Water Inlet Valve "WR57X10033"
Solenoid valve replacement is pretty straight forward. Usually all the is needed are some simple hand tools and a rag to pick up spilled water. Make sure the water supply is shut off and unplug the fridge before attempting.
If my answer was helpful - please rate it. Thanks & good luck!
Oct 05, 2011 | GE Refrigerators
I cant find the water filter in the ge gss22jet side by side fridge. I have a manual but it says the filter is on the fridge side on the top right. There is a picture of it in the manual as well. However,...
Hmmm, on that model number i searched 4 of my online parts suppiers and not a one of them shows a listing for the filter so despite what the manual says i belive that model does not have a built in water filter
Sep 17, 2011 | GE GSS22JET Side by Side Refrigerator
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Hi I have a GE Fridg. #GFSL6KEXALS Just has ice in bottom freezer, no water. Ice maker quit working, Does not seem to be filling with water.
Check the water line that goes from the house plumbing all the way to the inlet on the 'fridge. Are there any kinks? Dirt obstructing the line? You MUST BE VERY CAREFUL when pulling the 'fridge out to check. If you have a copper line, it takes NOTHING for one to kink. And as soon as it kinks...it's done.
Feb 23, 2010 | Refrigerators
I replaced the water filter for my GE GSH25JSTA SS side by side fridge and now the unit is no longer dispensing water
Mar 22, 2009 | GE Refrigerators
May 15, 2008 | Refrigerators
Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Sep 10, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
