Question about Pasquini Livia 90 Espresso Machine
Replace rubber gasket on livia 90
I simply need to replace the rubber gasket in the group head, and was interested in information on any tips, notes, etc., before I simply go in and "do it."
  • 1089 Answers
SOURCE: need a manual for Pasquini Livia 90
Hi I have one that I wrote if you want it. Send me your e-mail and I'll sent to you.
Posted on Jun 10, 2009
mrpsespresso
  • 16 Answers
SOURCE: Pasquini Livia 90 - No water from the group head
The problem could be calcium built up blocking the jet and stopping the flow of water through your 3 way solenoid valve.
Otherwise the 3 way solenoid has stopped working. The 3 way valve part #91004 is $105 + shipping.
If you capable of removing the top and 3 body side of the machine, you can contact me and I can walk you through diagnosing if this is the problem with the jet or the valve. Before you call, make sure you have a philips screwdriver, 14 and 15mm open ended wrench or crescent wrench, flashlight, and paper clip.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Posted on Nov 15, 2009
mrpsespresso
  • 16 Answers
SOURCE: Our Livia 90 would need a service + the pressure
If you are local to us perhaps in Orange County, CA we can provide service. If not you may contact Pasquini to get a local certified repair location near you.
As far as the pressure steam valve goes, you most likely simply need a new o-ring kit... we offer kits for new and older units. Older machines would use Part# KSWV-2 for $5.40, newer units would use Part# KSWV-2 for $4.30. I could explain how you could do this service yourself.
Posted on Apr 15, 2010
EsWorld
  • 1618 Answers
SOURCE: Pasquini Livia 90: heats up for about 5 minutes, then shuts off
Sounds like the pressure switch is not working properly and the safety is turning the machine off. Try checking the tube from the boiler to the pressure switch that might be blocked, if not then the pressure switch needs to be replaced.
Posted on Jul 22, 2010
bobicehouse
  • 1524 Answers
SOURCE: i need the parts diagram for the pasquini livia 90
They do not have any information available unless you contact them directly. http://www.pasquini.com/
Posted on Nov 18, 2010
Direction replacing goup solenoid
As you have put it water flows from boiler to group head so the arrow on the solenoid should be this direction.
Aug 15, 2012 | Pasquini Livia 90 Espresso Machine
Water gushes out of the group when back washing.
If you replaced the group gasket, then you might want to check the top of the blind filter basket to make sure it has no dents. If you were having the same problem while brewing espresso, I would say carefully remove the gasket and clean the head thoroughly then use a mirror and check to make sure there is no coffee or small pieces of rubber in there then put the gasket back on and try to brew a coffee. Since the problem is only happening when you backwash the only thing different is the basket.
Jun 04, 2012 | Pasquini Livia 90 Espresso Machine
I have a Pasquini Mod. LIVIA 90 120V 1200W. When I insert my group handle completely to the right to make coffee, it will slide to the left or comes out when it is inserted most of the times. Even if...
Hi
Yes you need a new gasket. They will normally last no more that 1 year. It's best to order 2 gaskets so you have one on hand when this happens, so you don't have to wait for the new gasket.
Aug 23, 2011 | Pasquini Livia 90 Espresso Machine
My machine has worked beautifully for several years, but suddenly, I have issues with the group head. When trying to pull my espresso, I get leakage around the rim of the group head. Sometimes coffee...
I have had the same issue, this is just the group head gasket that needs to be replaced. I got all the parts and I am going to try and replace it myself
Jun 09, 2010 | Pasquini Livia 90 Espresso Machine
The portafilter basket leaks out the sides no matter how firmly held in place or the quantity of coffee in the basket
Hi
You need to replace the brew head gasket. It becomes hard and will not seal. Order 2 gaskets because 1 always fails on Friday before a big party on Saturday.
Nov 29, 2009 | Pasquini Livia 90 Espresso Machine
The handle is leaking water
Hi
Your brew head gasket needs replacing. They get hard after about 6 months to a year depending on how long the machine is on. if it on 24/7 it need to be changed every 6 months. If turned off daily every year. The gasket is up where you install the portafilter to make espresso. The black ring is rubber and that is what need to be changed. Have one setting right here on my desk.
Nov 09, 2009 | Pasquini Livia 90 Espresso Machine
Filter basket sticking in the group head
It sounds like the solenoid is not discharging after a coffee is made, try back washing machine with purocaff. If the soap comes out of the small pipe on the right and dumps into the drain tray you are back in business if not you might to clear the pipe.
May 11, 2009 | Pasquini Livia 90 Espresso Machine
Leaking from the grouphead
The fix to this problem is replacing the group head replacement done every 8 months to a year. The part number is #90907 $4.50+shipping and I have this in stock.
Feb 18, 2009 | Pasquini Livia 90 Espresso Machine
Oct 18, 2008 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90 Espresso Machine Logo
162 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
