Question about 1311145 7.2 Volt Battery Pack
Need replacement diode for battery 1311145
Son plugged wrong charger cord to battery and blew out diode. Need replacement dioe
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 120 Answers
If you are in australia you can try Jay Car
Posted on Feb 21, 2014
HOW TO HOOK UP A CTEK BATTERY CHARGER TO A 2007 MASERATI QUATTROPORTE SPORT GT
Wise decision my friend. Because with all the electronic stuff that's still running without the switch on, it can destroy a good battery after a while of non-use. A very, very slow drain. Just connect the hot wire directly to a lead directly to the battery and the ground to a bolt on the frame. Place the male end of the 110 cord where you can easily access it to plug it into the extension cord and wire tie it there. Mount the charger in an area where it can get air, under the hood on a fender well but out of the way. Because these new style chargers are "floating" chargers, it will shut down when battery is fully charged and restart with a 1% drop. Always remember to disconnect the extension cord from charger before starting the car. Otherwise you'll be replacing the charger. It's safe to hard wire the unit like this, no power goes back to the charger with the one way diode that's incorporated in the unit. Have fun with your toy.
Jul 29, 2014 | Vehicle Parts & Accessories
No power after replacing the battery
Check hoy Red wire the Red wire is the problem good lake
Nov 26, 2012 | Polaris ATV
My portable dvd player won't come on
1) you must test the charger AC for DVD PLAYER, if working try to put in another DVD player, you must use the Vom FOR to measure the output voltage dc.or replace the charger.
2) if you are using batteries change batteries, clean the contacts batteries, with contacts cleaners, retight the spring contacts batteries for a good contacts.
3) if doesnot work, the problem is the power supply the trafo, filter, diode zener, bridge diodes, IC regulator voltage. etc. go to the repair shop TV for fix it.
God bless you
Jul 16, 2012 | RCA DRC629N Portable DVD Player
Xps 17 battery charger
I think either you have the wrong DC Power Jack installed (where the power cord plugs into the computer) or the wrong AC Adapter & Power Cord.
Hopefully you have an AC Adapter Power Cord that was made for your computer and not one of those one size fits all that some stores sell with the interchangeable tip at the end that plugs into the computer.
Mar 30, 2012 | Dell Xps 17 Laptop Computer (Intel Core i7...
We've just built my sons gator and plugged the charger into a socket which was attatched to the battery and it blew all the fuses in the house. The charger plug now has scorch marks on and won't...
probably going to need a new one, you can plug the charger in with out it being hooked up to the battery and test it with a multimeter to make sure that its putting out 12 volts
May 21, 2011 | Peg Perego John Deere Gator HPX Ride on...
I have a toshiba satellite x205-s9800. last night i was online and it just shut down. period. no warning...nothing. it felt pretty warm so i just let it sit and cool off. it still will not start this...
amm your system must have been going through alot of stress lately. there are two things.the power pack is faulty or the mother board is bad. so you just have to confirm which is wrong.
Sep 17, 2009 | Computers & Internet
Craftsman riging mower will not charge. Son hooked cables up wrong and most likely blew the diode. Where is the diode located?
if it is a briggs engine it is in the wiring harness coming off the alternator, where it plugs into the main harness coming out of the dash area. it will appear as a lump in the wire [sometimes there will be two diodes]. if it is a kohler, it will be in the wiring harness under the shroud covereing the flywheel
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Car Battery Charger - Repair
thats what i did on mine they blew when i hooked the cables up backwards (gotta watch that)
but i used 130 amp alt diodes from an old tractor alt i had
Jul 03, 2009 | Kitchen Appliances - Others
Makita DC18RA Li-Ion 18V Battery Charger
Most likely, but unless the transformer blew, which is somewhat unlikely, a good repair shop should be able to fix it. Basically the charger unit is a transformer, some diodes to convert ac into dc, and some sensing circuitry to tell you when the battery is done charging. Diodes and sensing cisrcuitry are commonly available parts and not expensive. Transformers are expensive. Even if you get it repaired youll still need an adaptor to convert from the mains 240 to the 120 that the charger wants to see. Get one with a high enough wattage for the charger. Wattage is printed on charger base.
May 17, 2008 | Makita 18V LXT Lithium - Ion Cordless...
1311145 7.2 Volt Battery Pack Logo
Top Ryobi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Ryobi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
