Question about Furuno 1623 Radar 16nm Range
Radar no video error - Furuno 1623 Radar 16nm Range
We have a garmin gps map 4012 and on radar just says radar error
This is a marine chartplotter and radar unit! I thought I didn't recognize the model :>) Check the connections are the rear, but more importantly to the connections to the radar dome.
The manual is here, but doesn't mention errors. You could of course contact Garmin direct.
http://jsca.bc.ca/wp/wp-content/uploads/2013/12/Garmin-5008.pdf
May 03, 2016 | Garmin GPS
Garmin radar error code 8
check the battery, some error due to battery problems, and then rest it for a while and then test.
melnavz
Aug 05, 2008 | Garmin Boating
I have radar JRC JMA-9303.and we find a trouble "trigger error"
After black out of ship during audit Radar Model JMA 9303 no work.
Radar start work and after 15 sec. switch off.
Radar not show target and display error "ANTCLK ER" ( Bearing pulses are not
sent to the display unit)and "TRIG ERR" unknown error.
Antena of radar working.
Any body can suggest the solution
Oct 09, 2012 | GPS
It is showing Error Code "A"
"A" is not an error code. It means "all bogeys" and should be working fine
Aug 07, 2011 | V1 Radar Detector
NMEA Output from Furuno 6" LCD Radar, Model 1623
No it does not output any type of radar video data.
Apr 27, 2010 | Furuno 1623 Radar 16nm Range
Do not get any images on the radar screen
depending on which radar it is, it may be the video coax inside the radar cable. Otherwise possibly your magnetron or mic. Try calling mid-shore electronics @ 410-228-7335 they may be able to assist you.
Nov 21, 2009 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Hello there, I have a 4' radar antena with a
ahh, this is an old one check the book.(ha, ha)
Press and hold menu during start up Choose "Installation Mode" Press "Menu" Select "Radar Set Up" Press "Next Page" Select "Radar Heading Alignment" Use knob and follow prompts, you will place the dotted line at dead ahaed and the
Select "Set"
Also, remember to TUNE VIDEO
Oct 08, 2009 | Furuno Navnet 1964CBB/NT vx2 Radar C Map...
Error SB SIG MISS on FURUNO CRT radar?
Either your reed switch is bad or your antenna is not rotating. You may hear the motor spinning but that does not mean the array is. If the array is not spinning make sure the belt did not come off the motor. Start there.
Jul 05, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Error BZ
This is a bearing pulse error. Either the bearing pulse generator inside the motor is bad (Replace the motor) or it's in the radar cable or display.
Jun 15, 2009 | JRC 1000 MKII Radar GPS Receiver
Escort passport 8500 error 13
This is an error message which indicates a specific internal component failure. Escort will have to fix your 8500.
Dec 30, 2008 | Passport 8500 Radar Detector
Furuno 1623 Radar 16nm Range Logo
29 people viewed this question
Top Furuno Boating Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Furuno Boating Expert? Answer questions, earn points and help others
