Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool refigerator GS5SHAXNB02 water dispenser dripping
SOURCE: whirlpool gold
Your drain was clogged. look for the drain funnel then remove the dirt.
Posted on Jun 14, 2008
lojacksdad
  • 121 Answers
SOURCE: Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Posted on Apr 17, 2009
  • 56 Answers
SOURCE: ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
Posted on May 30, 2009
  • 105 Answers
SOURCE: in-door water dispenser drips water
replace water filling valve as it probable has dirt between valve seat
Posted on Nov 21, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool refrigerator water dispenser won't stop
Hi. This will usually be the fault of the water inlet valve. The solenoid based valve may have debris building up, thus, causing the valve not to close properly, after usage. Kindly, follow the procedure below to confirm the damage, replace the valve, if needed.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Posted on Nov 25, 2009
My "Whirlpool Gold" Refrigerator's interior water dispenser was dripping pretty badly. I just replaced the inlet valve and the drip is MUCH slower but it's still there (1 drip every ~10 minutes). Wha
Perhaps some air bubbles were trapped in the water line during the repair. Try running water thru the line for a good amount of time and that may help to relieve the line of any air bubbles.
Jan 26, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Hi I have a Whirlpool Refigerator and it drips water from the frezzer into the refigerator thru the two opening up in the back middle opening from the frezzer to the refigerator. It does this off and on
sounds like the drain live from freezer to outside is clogged. the water isnt making it you the condensate pan but coming out in the refrigerator. try finding and cleaning the drain line.
Mar 02, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
Mar 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
In-door water dispenser drips water
Nov 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
How do I get the water dispenser on the outside of the door to quit dripping water
Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser.
Jun 30, 2009 | Whirlpool ED5FTGX Side by Side...
Ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water dispenser on my Whirlpool ED22PQXFW00 Refrigerator keeps dripping
Hi, this is a faulty water valve assembly that is not shutting the dispenser section completely. replacing this water valve assembly will fix the dripping issue you are having at this time.
Whirlpool Part Number: 2188542
May 14, 2009 | Refrigerators
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
16 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
