Question about Dryers
Clothes dryer problems
I live in Minnesota and my dryer in indoors and the room is 60 degrees but the temp in the dryer was 30 degrees and my clothes froze. How do I warm up the gas dryer to get it going again? Thank you for your help - Sears won't answer any questions over the telephone...they only will make a pricy service call? Kbcurley@earthlink.com
  • Dryers Master
  • 8,220 Answers
I would say remove the clothes from the dryer and set em somewhere they will thaw out then when they is thawed and the dryer is working ok put em back in the dryer. Never heard of clothes freezin in a dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 09, 2014
  • 35 Answers
SOURCE: soot in gas dryer
it sounds as though your dryer may need to be converted for the use of lp gas.or you might have a burner problem.
Posted on Jun 05, 2007
SOURCE: Gas dryer does not dry clothes
try replacing the solenoids/coils.
Posted on Jan 10, 2008
SOURCE: HotPoint Dryer Model Number NVLR333EVOWW not getting hot
Set the timer one day, later clothes not warm at all, dryer still running and timer had not moved. It has never heated up again. Can you help me figure out the problem? Where all the heating elements, thermostats etc may be. thank you for your help.
Posted on Nov 24, 2008
SOURCE: samsung dryer is not drying and its new
It ended up being a easy fix. Our old dryer was working fine and had been ran an hour before I hooked up the new Samsung dryer. Therefore I assumed when the new dryer did not work there had to be something wrong with it. There ended up being nothing wrong with it and it was my dryer vent. It was barley plugged which caused it to not heat up properly. I was told that the new dryers have a lot more sensors on them and its very sensitive about needing a clean vent to vent out the heat. My vent was not very dirty, but it had just enough build up of lent in it, it caused the dryer to not vent properly and it would keep shutting the flame off. Blew it out with my leaf blower and now it heats up and dry quick. I hope this helps
Posted on Feb 15, 2009
SOURCE: Gas Dryer Heats up very little, but not enough to dry my clothes
you need to check that for vent hose is not kinked if it is not then remove it from the dryer and see if it work right if it does then the vent tube that goes thourgh the wall has a blockage
Posted on Feb 25, 2009
Front grill
Check the air filter and if it is dirty, replace..
Turn equipment off and let the ice melt.
After ice melts, place a/c in cooling mode and set the thermostat to 3 degrees below room temp display.
The indoor unit fan should start blowing cold air immediately and then turn off once the room temp drops one degree below the cooling temp setting.
If the indoor unit does cycle off, check the outdoor unit and make sure it turns off at the same time.
If the outdoor unit continues to run and the indoor fan is not running, the indoor unit will ice up.
A defective compressor relay that is stuck in a closed position will cause icing of the indoor unit because it keeps the compressor running when it should turn off with the indoor fan.
Do you have an error code being displayed on the controller?
Is there an led light that is flashing on the indoor unit?
Another possibility causing the indoor unit to ice up is if the freon in the system starts to get low.
Make sure the ice has all melted for this next check.
Pretty easy to check without special tools.
If the air filter is clean and there is no dust/ dirt blocking the fins on the indoor unit, turn a/c back on to cool and check that the indoor unit fan comes on and is blowing air good.
Once everything seems to running good go to the outdoor unit.
There will be two lines with black rubber insulation covering them.
Peel back the insulation three inches on each line and observe the copper lines.
If either line starts to frost up the a/c system is most likely low on refrigerant.
Another cause of indoor unit icing could be that the aluminum fins behind the air filter are clogged with dust or other foreign material.
This would block the air that must be pulled in causing the indoor unit coil to become too cold due to lack of air flow and it will ice up.
Operating the cooling system when the outdoor temperature is below 60 degrees can cause the indoor unit to ice up also.
I'm Robert.
Florida certified a/c contractor. 30 years experience.
Hope this helps.
Mar 18, 2014 | Fujitsu Heating & Cooling
Our clothes come out with a black hardened materiel. The rear screen on drum has materiel melted onto it that appears to be melting during drying cycle and transferring to clothes. Does the screen come...
No it does not and even if it did the dryer's internal temp should not exceed 230 degrees and that would not be hot enough to melt any part of that dryer. Any warmer and it would scorch your clothes. Check for something that came out of a pocket, or some other way was introduced to the dryer.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Aug 04, 2013 | Frigidaire Dryers
The heat sistem is not working well is working but 30% of eficency than it was working beafore.It hear like water on it ..help im frezzing
Air conditioning real definition is not giving cool but removing heat from the room. In same way for heating, it's not heating, removing cool from the room. When your indoor coil, air filter and blower wheel are full of dust, you won't get even 30% of cool or heat depend on your selection.
Simple solution for your problem is clean indoor unit completely. Check all sensor is working well. In heat mode keep temp minimum +3 degree than room temp. thanks and helpful.
Jan 30, 2011 | LG LS-L1210CL Mini Split Air Conditioner
When i change the temperature to make it hotter, the screen blinks then goes back to being 30 degrees colder. Is my heater ignoring my request because it never reaches the temperature i want it to. it...
First you have to understand in thermostat there are Fahrenheit & Centigrade degree. If Centigrade between 16 to 30 and if it is Fahrenheit 60 to 86.
If you press the symbol ther> and > (or) ther- and ther+ at a time degree will change.
Now you set your temp +10 degree from your room temp and also keep "heat" mode.
Dec 14, 2010 | Heating & Cooling
My whirlpool AWZ510E washer dryer - the dryer doesn't seem to be working - it goes through the cycle but the clothes are still as wet as before. I am using the same cycle as I always have which used to...
there are 3 reasons for a dryer not doing the job yet running through the motions. 1st, the heat is not being produced and only cool room temp air is circulating. this can be a burned-out electric element or an over-heat sensor, or in0line safety fuse. ( if gas, can be ignitor or gas valve coils).. It could be that the washer is not ringing (spinning) dry the clothes verywell and there is too much moisture stiil in clothes which would double the dry time from 50-60 minutes to 2 hours. 3rd, could be clogged vent line and the hot moist air cannot leave the dryer so the clothes get hot by the moisture stays.
Apr 28, 2010 | Whirlpool Washing Machines
I have a GE air conditioner with ditigal panel. I
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
Jun 28, 2009 | GE AJCQ08ACB Air Conditioner
Samsung 8000 btu window air conditioner
Air conditioners rely on a difference in pressure between the "high side" and "low side" in order to perform. Of course, a/c's are designed to work in the heat. Having a cooler outdoor temp of 70 degrees probably is not sufficient to maintain adequate head pressure and will result in reduced cooling capacity. Also, since it was 68 in the morning in the room, it is possible that the indoor coil began to freeze up. Basically, you have a cold coil that you keep warm by moving air over it. If the air doesn't have enough specific heat (what your thermometer measures) it can allow the coil to get colder than 32 degrees and the condensate from all of your humidity will begin to freeze on the coil. My recommendation would be to check the a/c on a day that is 80+ degrees. If you have an avarage indoor temp of 70 degrees you should be able to look for the air coming out to be approximately 20-25 degrees colder than the air being sucked in.
Jun 10, 2008 | Heating & Cooling
Kenmore Elite H3 Dryer taking longer than normal to dry clothes
EVEN THOUGH THERE IS WARM AIR COMING OUT THE EXHAUST, IT STILL MAY HAVE A RESTRICTION IN THE DUCT WORK. DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER FOR ONE LOAD OF LAUNDRY. IF IT DRYS THE CLOTHES O.K., YOU HAVE A RESRICTION SOMEWHERE IN THE EXHAUST.
NOTE: DO NOT USE VINYL OR PLASTIC DUCTING. VINYL IS NOT U.L. APPROVED. PLASTIC PVC WILL ALLOW CONDENSATION TO PUDDLE INSIDE THE PIPE CAUSING A
COMPLETE RESTRICTION.
Mar 30, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
55 people viewed this question
Top Dryers Experts
