Question about Fitbit Aria Wi-Fi Smart Bathroom Scales White
Reset button fitbit aria - Fitbit Aria Wi-Fi Smart Bathroom Scales White
    New Friend:
  • 3 Answers
There should be a pin hole located on the bottom of the scale, insert pin or paper clip to reset.
Posted on Nov 29, 2014
How do I reset the time on my Alta fitbit?
Theoretically the Fitbit should keep the time updated though syncing. I would try these steps in this order.
1. Re-sync your Fitbit to your phone/computer
2. Check your settings on your dashboard to make sure you have the correct time zone selected.
3a. If you sync to a phone make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit (in your Bluetooth settings).
3b. If you are syncing to a computer, then try re-syncing your Fitbit. you might need uninstall/reinstall your software and make sure you are running the most recent version.
4. Try removing the device in the Fitbit app (should be under device settings) and then reconnecting it.
Hopefully one of those steps will get you on the right time, but if not, try resetting your Alta by doing the following:
Plug in your Alta in a USB (computer, or adapter) as you normally would to charge it. It should begin charging.
Press the button on your charging cable three times within eight seconds, briefly pausing between presses. (The button is on the end of the charging cable).
Eight seconds after the first button press, you'll see the Fitbit logo on the screen. This means Alta is restarting.
After you see the logo you can unplug your tracker from the charging cable.
Hopefully one of those things will get you on the correct time :)
Oct 20, 2017 | Exercise & Fitness
How do I reset the time on my Fitbit watch
Here is the way you can reset time on your Fitbit without Reset Fitbit Charge HR -
  • Open the Fitbit app on your phone
  • Then Go to the Advanced Settings
  • Now turn off automatic Time Zone
  • Press Select Time Zone
  • Choose the time zone according to your country
  • Synchronize your Fitbit to your smartphone
The Guide Of Reset Fitbit Charge HR Complete Guide
Aug 08, 2017 | Exercise & Fitness
How do I reset the time on my fitbit charge?
How to Reset Fitbit Charge HR
  • Connect the charging cable to your tracker and plug the other end into a USB port
  • Press and hold the button for around two seconds and deprived of letting go of the button take away the charging cable from your tracker
  • Wait about six to ten more seconds after removing the charging cable discharge the button and keep holding it down again
  • Once "ALT" and a white screen flash, discharge the button and keep holding it down again
  • After you feel a vibration, discharge the button and keep holding it down again
  • As soon as you see "ERROR," discharge the button and keep holding it down again
  • As soon as you see "ERASE," discharge the button. The tracker is going to turn off
  • To about-face your tracker aback on, essayist the button or attach the charging cable (make abiding by bung in the added end of the cable). When you can see the time on your tracker is 0:00, you have successfully reset your device.
  • Next, you'll tell your Fitbit account that you're setting up a new tracker
That's how you can Reset Fitbit Charge HR and Fitbit Charge.
Dec 04, 2016 | Exercise & Fitness
Can the screen cover on a A Fitbit HR Charge be replaced
It can!
(6-Pack) EZGuardZ Screen Protector for FitBit Charge HR (Ultra Clear ...
https://www.amazon.ca/6-Pack-EZGuardZ-Screen-Protector-FitBit/dp/B00SVW2DPO
  1. Cached
Pack of 6 Brand New EZGuardZ™ Screen Protectors; Precision Cut for your FitBit Charge HR, NO Cutting Necessary; No worrying about sticky residue; Thin, ...
Screen Protector And How To Get Scratches Out - Fitbit Community
https://community.fitbit.com/t5/Charge-HR/Screen-Protector-And-How.../835469
  1. Cached
Jun 21, 2015 - If you have a Fitbit Charge HR, I highly recommend getting a screen protector. The plastic screen is not strong at all, and it is also very easy to.
Best screen protector brand for Charge 2. - Fitbit Community
https://community.fitbit.com/t5/Charge-2/Best-screen-protector...Charge.../1543173
  1. Cached
Sep 2, 2016 - Wendy ' California. Retired Classic, Ultra, Charge,Charge HR. In use One, Charge 2, Surge, Blaze, Alta and Aria ' Windows 10 ' Android Moto ...
Amazon.com: XtremeGuard™ Screen Protector for FitBit Charge HR ...
https://www.amazon.com/XtremeGuardTM-Screen-Protector-FitBit-Charge/.../B00SV...
  1. Cached
Buy XtremeGuardTM Screen Protector for FitBit Charge HR (Ultra Clear): Screen Protectors - Amazon.com ? FREE DELIVERY possible on eligible purchases.
FitBit Charge & FitBit Charge HR Watch Front INVISIBLE Screen ...
https://www.amazon.com/INVISIBLE-Protector-included-Protection.../B00UMAXNJS
  1. Cached
Buy FitBit Charge & FitBit Charge HR Watch Front INVISIBLE Screen Protector (Front Shield included) Military Grade Protection Exclusive to ACE CASE: Screen ... screen cover on Fitbit HR Charge Google Search
Nov 16, 2016 | Exercise & Fitness
Can the screen be replaced on a fitbit charge hr
  1. Cached
  1. Cached
  1. Cached
  1. Cached
  1. Cached
When I press the button the only thing that will display is the time and then it turns back off. How do I correct this.
Make sure your Fitbit is fully charged by plugging it into its charger, it should vibrate and you want to see a fully white battery indicator when pressing the button.
While it is on its charger let's do a reset, by holding there button until you see the Fitbit logo.
Jun 01, 2015 | Fitbit Charge Wireless Activity Tracker...
My Charge Fitbit is not holding a charge. Yesterday it was dead within 1.5 hours. I have used the paperclip to try to reset without success. I am ready to throw in the towel so to speak.
You can put the software right, with a reset. Hardware errors and batteries won't change a bit when you use the reset button. When the battery is bad, and it looks that way, just return the Fitbit and ask for a new or new battery. It still should be under warranty. If the warranty is only 90 days for the battery, never again buy a Fitbit in the place you are living. In Europe electronics have a warranty of 24 months.
Apr 19, 2015 | Fitbit Charge Wireless Activity Tracker...
My 16 gb gogear froze
1 On your computer, select Start >
Programs > Philips Digital Audio Player
> Aria Device Manager > Philips Device
Manager to launch the Philips Device
Manager.
2 Turn off GoGear Aria before you
continue.
3 Press and hold the volume button
while you connect GoGear Aria to your
computer.
4 Keep holding the key until the Philips
Device Manager acknowledges GoGear
Aria and enters the recovery mode.
5 On the computer, click the Repair
button and follow the instructions of the
Philips Device Manager to complete the
recovery process.
6 When the recovery is completed,
disconnect GoGear Aria from your
computer.
7 Restart GoGear Aria.
The full manual is found here: http://www.p4c.philips.com/files/s/sa1ara16k_17/sa1ara16k_17_dfu_aen.pdf
Oct 29, 2009 | Audio Players & Recorders
Fitbit Aria Wi-Fi Smart Bathroom Scales White Logo
2,110 people viewed this question
Top Fitbit Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Fitbit Health and Beauty Expert? Answer questions, earn points and help others
