Question about Whirlpool LCR7244H Top Load Washer
LCR7244HQ transmission
I want to remove my trasmission
Yes the engine has to be out,its not a easy task to replace transmission.You will required professional tools and wrench/ratchets.
Also its very time consuming.
For your help,i suggest you few help links with accurate solutions,showing how exactly to replace transmission and other transmission components.
Click the link below:-----
HOW TO REPLACE A MANUAL TRANSMISSION
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-manual-transmission.html
HOW TO REPLACE TRANSMISSION COOLER LINES
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-transmission-cooler.html
HOW TO CHECK AUTOMATIC TRANSMISSION FLUID LEVEL
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
HOW TO CHANGE AUTOMATIC TRANSMISSION FLUID AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
HOW TO REPLACE A TRANSMISSION MOUNT
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-transmission-mount.html
DSG automatic transmission problem
http://whatisbyme.blogspot.in/2012/07/dsg-automatic-transmission-problem.html
Transmission problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-problem.html
2004 Chrysler 300m: Transmission Relearn Procedure?
http://repairhelpcenter.blogspot.in/2012/06/2004-chrysler-300m-transmission-relearn.html
How do you change transmission fluid on Pontiac?
http://schematicsdiagram.blogspot.in/2012/03/how-do-you-change-transmission-fluid-on.html
Filling Transmission fluid on 2001 Volvo c70?
http://schematicsdiagram.blogspot.in/2012/02/filling-transmission-fluid-on-2001.html
2002 Isuzu trooper Transmission fluid fill up?
http://schematicsdiagram.blogspot.in/2012/02/2002-izusu-trooper-transmission-fluid.html
AUDI V8 TRANSMISSION FLUID
http://whoisbyme.blogspot.in/2012/07/audi-v8-transmission-fluid.html
Where to fill Transmission Fluid on 2001 ford focus
http://technoanswers.blogspot.com/2012/10/where-to-fill-transmission-fluid-on.html
Coolant enters in transmission on Toyota Land cruiser?
http://schematicsdiagram.blogspot.com/2012/01/coolant-enters-in-transmission-on.html
Engine stumbles and shuts off in forward gear on Toyota Land Cruiser?
http://schematicsdiagram.blogspot.com/2012/01/engine-stumbles-and-shuts-off-in.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
Manual Transmission Clutch System Failures?
http://repairhelpcenter.blogspot.com/2011/11/manual-transmission-clutch-system.html
Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Transmission fluid gets into radiator?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fluid-gets-into-radiator.html
Dodge Anti slip System is not operating?
http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
How to check Transmission fluid on 1996 Chevrolet Camaro?
http://schematicsdiagram.blogspot.com/2011/12/how-to-check-transmission-fluid-on-1996.html
Transmission fault light on car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Filled T-IV fluid instead of WS transmission fluid?
http://repairhelpcenter.blogspot.com/2012/01/filled-t-iv-fluid-instead-of-ws.html
Manual transmission very hard to shift from one gear to another?
http://repairhelpcenter.blogspot.com/2012/01/manual-transmission-very-hard-to-shift.html
Bell housing and transmission will not come apart on 1996 Toyota Tacoma?
http://repairhelpcenter.blogspot.com/2012/01/bell-housing-and-transmission-will-not.html
How to Add transmission fluid on 2002 Isuzu AXIOM?
http://technoanswers.blogspot.in/2012/02/how-to-add-transmission-fluid-on-2002.html
Chrysler Cirrus Auto Transmission Swap?
http://whoisbyme.blogspot.in/2012/06/chrysler-cirrus-auto-transmission-swap.html
These details will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
Tranmission ands four wheel drive locked out
For Automatic transmission problem,click the link below:---- Automatic transmission troubleshooting:----
Automatic transmission shift lever issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
AUTOMATIC TRANSMISSION FLUID AND FILTER?
Transmission shifting problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This will help.
Thanks.
Feb 22, 2012 | 1998 Mitsubishi Montero Sport
Disconnect shift linkage
This will help.
Thanks.
Feb 11, 2012 | 2003 Mini Cooper
Shifting solenoids on 2002 Lancer.
This will help.
Thanks.
Feb 08, 2012 | 2002 Mitsubishi Lancer
My 1993 chrysler concorde transmission will not shift into overdrive, had another transmission placed, has same prob, what could be causing it?
This will help.
Thanks.
Feb 07, 2012 | 1993 Chrysler Concorde
On a 95 caprice classic, what would cause the transmission to slip?
For Automatic transmission problem,Check the list of help links below.click the link below:----Automatic transmission troubleshooting:----
This will help.
Thanks.
Feb 07, 2012 | 1995 Chevrolet Caprice Classic
TORQUE CONVERTER CLUTCH SOLENOID
This will help.
Thanks.
Jan 31, 2012 | 2003 Land Rover Discovery
Slipping
This will help.
Thanks.
Jan 29, 2012 | 2003 Cadillac Deville
How to remove a transmission for a 2002 GMC Yukon
Removal & Installation 4L60E/4L65E To Remove:
  1. Remove or disconnect the following:
    • Transmission fluid
    • Transmission oil level indicator tube and seal from the transmission
    • Plug the oil level indicator tube opening in the transmission.
    • Remove or disconnect the following:
    • Shift cable end from the transmission shift lever ball stud
    • If equipped with a transfer case, remove the front propeller shaft.
    • Rear propeller shaft.
  2. Plug the transmission oil cooler line connectors in the transmission case.
  3. Remove or disconnect the following:
    • Starter motor.
    • Transfer case, if equipped.
  4. Support the transmission with a transmission jack.
  5. Remove the transmission mount nuts.
  6. Remove the transmission crossmember.
  7. Remove or disconnect the following:
    • Torque converter access plug 4L60E/4L65E removal 9308kg37.gif
    • Flywheel to torque converter bolts
    • The two bolts securing the transmission rear mount to the transmission
    • The transmission vent hose, fuel lines, and the wiring harness from the transmission
    • The stud and the bolt securing the transmission to the engine
    • The six studs and one bolt securing the transmission to the engine. Install tool J21366 onto the transmission bell housing to retain the torque converter. Pull the transmission straight back.
    • The transmission from the vehicle
  8. Flush the transmission oil cooler and cooling lines when you remove the transmission.
To Install:
  1. Install or connect the following:
    • Tool J21366 onto the transmission bell housing to retain the torque converter.
    • Support the transmission with a transmission jack.
  2. Raise the transmission into place and remove the tool from the transmission.
  3. Slide the transmission straight onto the locating pins while lining up the marks on the flywheel and the torque converter. The torque converter must be flush onto the flywheel and rotate freely by hand.
  4. Install or connect the following:
    • Six studs and one bolt securing the transmission to the engine. Tighten the studs and the bolt to 50 Nm (37 ft. lbs.).
    • Stud and bolt securing the transmission to the engine. Tighten the stud and the bolt to 50 Nm (37 ft. lbs.).
    • Flywheel to torque converter bolts. Tighten the stud and the bolt to 46 Nm (63 ft. lbs.).
    • Torque converter access plug.
    • Transmission vent hose, fuel lines, and the wiring harness to the transmission.
    • Two bolts securing the heat shield to the transmission. Tighten the bolt to 17 Nm (13 ft. lbs.).
    • Two bolts securing the transmission rear mount to the transmission. Tighten the bolts to 18 ft. lbs. (25 Nm).
    • Install the transmission crossmember. Tighten the nuts and bolts to 70 ft. lbs. (95 Nm).
  5. Remove the transmission jack from the transmission.
  6. Unplug the transmission oil cooler line connectors in the transmission case.
  7. Install or connect the following:
    • Starter
    • Transmission oil cooler lines to the transmission
    • If equipped with a transfer case, install the front propeller shaft.
    • The rear propeller shaft
    • The shift cable end to the transmission shift lever ball stud
  8. Unplug the oil level indicator tube opening in the transmission.
  9. Install the transmission oil level indicator tube and seal to the transmission.
  10. Tighten the oil pan bolts and fill the transmission with transmission fluid.
  11. Lower the vehicle.
4L80E/4L85E To Remove:
  2. Plug the oil level indicator tube opening in the transmission.
    • Shift cable from the transmission shift lever ball stud
    • If 4WD vehicle, remove the propeller shaft.
    • If RWD vehicle, remove the propeller shaft.
    • The transmission oil cooler lines from the transmission
  4. Plug the transmission oil cooler line connectors in the transmission case.
  5. Remove or disconnect the following:
    • Starter motor
  6. Support the transmission with a transmission jack.
    • The two bolts securing the heat shield to the transmission
    • One nut and one bolt securing the transmission brace to the engine bracket and transmission
    • The two bolts securing the torque converter cover to the engine
    • The four bolts securing the torque converter cover to the transmission
    • The six flywheel to torque converter bolts
    • The two bolts and nut securing the transmission rear mount to the transmission
    • The stud and the bolt on the right side securing the transmission to the engine
    • The remaining six studs and the one bolt securing the transmission to the engine
    4L80E/4L85E removal 9308kg36.gif
  8. Pull the transmission straight back. Remove the transmission from the vehicle.
  9. Flush the transmission oil cooler and cooling lines when you remove the transmission.
To Install:
  2. Support the transmission with a transmission jack.
  3. Raise the transmission into place and remove the tool from the transmission.
  4. Slide the transmission straight onto the locating pins while lining up the marks on the flywheel and the torque converter. The torque converter must be flush onto the flywheel and rotate freely by hand.
  5. Install or connect the following:
    • The stud and bolt on the right side securing the transmission to the engine. Tighten the stud and the bolt to 50 Nm (37 ft. lbs.).
    • Six flywheel to torque converter bolts. Tighten the bolts to 60 Nm (44 ft. lbs.).
    • The two bolts securing the torque converter cover to the engine. Tighten the bolt to 50 Nm (37 ft. lbs.).
    • The four bolts securing the torque converter cover to the transmission. Tighten the stud and the bolt to 33 Nm (24 ft. lbs.).
    • The transmission vent hose, fuel lines, and the wiring harness to the transmission.
    • The two bolts securing the heat shield to the transmission. Tighten the bolt to 17 Nm (13 ft. lbs.).
    • The two bolts and nut securing the transmission rear mount to the transmission. Tighten the bolts and nut to 25 Nm (18 ft. lbs.).
    • The flywheel to torque converter bolts.
    • One nut and one bolt securing the transmission brace to the engine bracket and transmission. Tighten the bolts and nut to 50 Nm (37 ft. lbs.).
  6. Remove the transmission jack from the transmission.
    • Starter motor
  8. Unplug the transmission oil cooler line connectors in the transmission case.
  9. Connect the transmission oil cooler lines to the transmission.
  10. Install or connect the following:
    • The transfer case
  11. Unplug the oil level indicator tube opening in the transmission.
  12. Install the transmission oil level indicator tube and seal to the transmission.
  13. Tighten the oil pan bolts and fill the transmission with transmission fluid.
  14. Lower the vehicle.
Oct 12, 2010 | 2002 GMC Yukon XL
Whirlpool LCR7244H Top Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
