Question about Radio Shack Pro-97 Handheld Scanner
WHERE IS THE BUTTON i PUSH TO UNLOCK ALL CHANNELS
  • Radio Shack Expert
  • 509 Answers
Turn the scanner on. press 'manual'. press and hold 'L/O' 'lockout' for 3 seconds and it will unlock all locked out channels. now press 'scan'. if you have nothing, then press 'scan' again and press each one of the number keys to turn off and to switch on the scanning banks. Okay? Let me know if you need more help.
Posted on May 01, 2017
Why won't my BC145XL scan
push manual on the scanner push manual again to see if the channel changes if so then push the scan button , if still no scan see if the volume is turned up. if not turn it up and see if you have any white noise , if you have what is called white noise turn the squelch till the noise is gone then press scan if it still does not scan you may have all the channels locked out and if so they need to be unlocked refer to the manual to know how to unlock channels then try again if that does not work scanner may need to be repaired
Jul 02, 2014 | Uniden BC350C Base Scanner
How do I unlock channels (pro-2055)
the unlock command is done from the manual mode.
If you scanner is in the scan mode, push the "MANUAL"button to stop the scanning feature.
Next you need to go to the channel you want to unlock. If you are only a few channels away, while in the manual mode, push the up or down arrows to step (one push per channel to be stepped though) to the channel to be unlocked.
A direct method is to enter the channel number on the keypad and then push the "manual" button. The display should show the channel you desire.
If the channel lockout is on, the second line on the display will show "LO+". Push the keypad button marked "L/OUT" once. The "LO+" should change on the display from uppercase to a lowercase "lo+". The channel is now unlocked.
Oct 16, 2009 | Radio Shack Pro-2055 Base Scanner
Cannot unlock Uniden BC60XLT-1 (30 ch VERSION)
if all the channels are 000.000 then it wont scann youll have to hit manual then enter a freq then hit the "e" button. once you hit manual youll be able to push the up and down arrows to select an channel you wish to imput a feq. Hope this helps.
David
Jun 29, 2009 | Uniden BC60XLT Handheld Scanner
L/O is on all channels cant program with L/O on it
push manual then hold down lock 0ut button for several seconds this should unlock all
Feb 14, 2009 | Uniden BC60XLT Handheld Scanner
Unlocking channels
first press the manual button so you can go through the channels one by one. Then look for a button that has L/O(lock out) push this once for every channel you have a frequency programmed for it, the channel will probably not unlock if there is no frequecy programmed to it.
per roupe50 above
Dec 25, 2008 | Radio Shack Pro-95 Handheld Scanner
Motorola Talkabout Basic
I believe you do not need to hold the monitor button when changing channels
Push the talk button till you have the channel you want then push monitor button to accept
Hope this works
Dec 16, 2008 | Motorola Walkie Talkie 2-Way Radio
Scanning programmed channels
Not exactly. You can program channels however into the Private bank. To do so though you must search for the channel first...This may simply mean going to a channel you already know by using the band button to start searching...Push the hold button to stop it close to the frequency and then use the arrow keys to get to the exact frequency. then push the Prog button. After pushing it, push the Private button (you will see CH next to the frequency) using the arrow keys select the channel you want to store on and push Prog again. To scan the stored channels simply push the private button...Done! It can be a tedious process...expecially with 50 channels....but It's the only way I know how to do it...Good luck!
May 11, 2008 | Uniden BC350C Base Scanner
Locked out!
press and hols down the "LOCK" for three seconds
Aug 16, 2007 | Radio Shack Pro-82 Scanner
Radio Shack Pro-97 Handheld Scanner Logo
47 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
