Question about Sram Cycling
How to install a sram red chain catcher - Sram Cycling
3 Suggested Answers
richard191
  • 691 Answers
SOURCE: just installed sram pc991 with shimano xt goupset. the chain
Hello
Thank you for using
FixYa for your problem
You have replaced front and rear chain rings too
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 26, 2009
dunnbiker
  • 8546 Answers
SOURCE: How cam I get my
http://www.parktool.com/blog/repair-help/front-derailleur-adjustments
Posted on May 15, 2011
Why has the tension in my pivot arm gone slack on my sram apex rear mech?
Chain is hung up on either derailuer or bottom bracket
Aug 14, 2014 | Sram Apex Double Tap
I have a brand new Red 22 group set up on a new Masi Evolution Frame. After about 400miles the chain started to derail off the lower rear derailleur tension wheel when ever I hit a bump while riding in the...
sidjjjjjjjjjjjjjjjjjjjjjjjjjjjjlkdjasjdnjkahdasnjdhabnsabdabhbnsabdnmabdjkhjkwqb wsnbjhbguysahbdagbxhjasbx njabgdyhabsk,dmankjxhigbknbchsgjanmanjaabjbsahgsavbnbsahgsabjnsbajhsajnmsa,hauisjanmsayihanm,.saaiosaiklnma,. saskalhhanm
Mar 01, 2014 | Sram Red 22 Groupset
The front derailer on my sram red compact just wont change quick!
Which brand of shifters are you using? A SRAM derailleur won't work with Shimano shifters and vice-versa.
So - first; if you are using SRAM shifters with the Red derailleur - then changing to Shimano will not solve your issue but only make it worse.
If however you have Shimano shifters - then this is a good solution.
The Red derailleur should not shift that poorly with SRAM shifters. It is not the best - but it's not bad. If I had the bike in a repair stand I would be looking carefully at the following after affirming that the shifting system was indeed all SRAM:
  • Derailleur cage height relative to the large chanring - should be a maximum of 2 mm
  • Derailleur cage should be aligned as close to parallel to the rings as possible
  • Derailleur upper and lower limit screws should be adjusted within spec and in order to allow the derailleur to travel the correct amount for ideal shifting
  • Derailleur cable tension should be correct.
Hope this helps... Let me know if you need more.
Oct 28, 2012 | Sram Red
Hi, my front mech wont change smooth. It is a compact chain set. From new it would never change like it should. takes lots of time and peddling to change.I
If not too late return it to the place that sold it to you and request it be fixed to work properly. Otherwise take to a bike shop or bike co-op. Alternatively go to Repair Help or Sheldon Brown Bicycle Technical Information to learn how to fix it yourself
Nov 10, 2017 | Sram Red
Question, . . need to replace chain Will a Sram PC-971 Chain work on my 8 speed road bike? Thanks T.K Yandell
Nope - This is a 9spd chain. The gears on a 9spd are narrower than on an 8spd. If you are going to use a SRAM chain you need one that starts with an 8 such as PC-850.
Any 8spd chain will work fine, Shimano, SRAM, whatever.
Nov 21, 2010 | Cycling
Sram Red outer chain ring problems. I have been a bicycle mech since 1994. I have a customer with sram red chain rings. He was in outer ring 53T and smallest cog rear cassette. The outer chain ring folded...
im in the industry aswell hmmmmm never heard of any recalls but i know quality speaks volumes of whether i would buy product from which i see an obvious quality based failures ive has similar issues and reported them sram said abuse without even looking at the issue we since have discontinued their line of products hope this helps
Nov 16, 2010 | Sram Force Crankset 53/39
Just installed sram pc991 with shimano xt goupset. the chain
Hello
Thank you for using
Thanks
Richard Scott
Technical Support
New Zealand
Oct 27, 2009 | Sram Pc991 Chain Speed
Installed new front sram x9 trigger shifter & its overshifting
You might have to consider changing your bottom bracket for one with a longer shaft. Examine your chain line and do some research here:http://www.parktool.com/ and also here:http://sheldonbrown.com/gearing/index.html
Oct 15, 2009 | Cycling
Cycling Logo
Top Sram Cycling Experts
Michial Gueffroy
Mike
dante
Are you a Sram Cycling Expert? Answer questions, earn points and help others
