Designfoil r6 crack code - Computers & Internet
How to fix yamaha r6 2008 error code 46
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
R6 fault Code 46
2006 R6 Low Charging Voltage FIXED Stator Test Error Code 46
Yamaha Fault Codes motorcycle manuals
2008 2009 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
YAMAHA YZF R6 Owner Manual
May 26, 2014 | 2008 Yamaha YZF-R6
Cracked sleeve
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6-forum.com/forums/57-garage-mechanical-help/312954-anyone-fixed-hair-line-crack-r6-cylinder-any-advice.html
http://www.r6messagenet.com/forums/r6-warranty-premature-failure/35530-piece-cylinder-sleeve-missing-pics.html
1999 2002 Yamaha YZF R6 Service Manual R6 Moto Data Project
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Nov 11, 2012 | 2000 Yamaha YZF-R6
2008 yamaha r6 error code 18
http://www.r6-forum.com/forums/46-general-discussions/57813-r6-2k7-error-code-18-a.html
How To Yamaha R6 homemade exup servo plug Code 17 18
Jun 09, 2012 | 2008 Yamaha YZF-R6
What is error code 11 14 46 on 2003 yamaha r6
R6 fault Code 46
Error Code 14
07 r6 Error code 11 after pcIII install HELP
2003 2004 Yamaha YZF R6 Service Manual R6 Moto Data Project
May 28, 2012 | 2003 Yamaha YZF-R6
Every once in a while my 2002 r6 will sputter when i crack it open and around 130mph it just shuts off.but then i pull over let it sit for about 5 min and it starts rite back up.
Hi, Traverchrist and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark.
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP sensor.
9. Intake air leak.
10. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Fuel tank vent system plugged or carburetor vent line closed off.
12. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
13. Carburetor controls misadjusted.
14. Damaged carburetor.
15. Incorrect valve timing.
16. Weak or broken valve springs.
17. Damaged intake or exhaust valve.
18. Check for engine trouble codes
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Sputtering split second cut outs during acceleration
http://www.r6messagenet.com/forums/r6-maintenance-technical/97754-2001-r6-surging-bogging-loosing-power-over-20-throttle-2.html
Mar 15, 2012 | 2002 Yamaha YZF-R6
2007 r6 wont start after installing exhaust code 14
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
http://www.r6messagenet.com/forums/r6-maintenance-technical/143249-newbie-my-bike-wont-start-throws-code-14-a-4.html
http://www.r6-forum.com/forums/57-garage-mechanical-help/60783-07-r6-engine-code-14-bike-wont-start.html
2007 Yamaha YZF R6 Service Manual R6 Moto Data Project
Jan 03, 2012 | 2007 Yamaha YZF-R6
Yamaha R6 2003 (first of the fuel injection) bike idles but as soon as you go to turn the throttle revs go to 6000 and stay there for up to 40 seconds after the throttle has been shut off (butterflies are...
Hi, Jack and the usual suspects are:
1. Faulty TPS-IAC-MAP-ETS-ISP sensor and or o-ring.
2. Throttle plate stop shifted.
3. Throttle plate shaft cracked-broken-faulty o-rings.
4. Throttle body to cylinder head seals/gaskets leaking.
5. Throttle cables improperly adjusted-damaged-kinked etc.
6. Vacuum lines cracked or broken or missing.
7. Faulty fuel tuner or out of adjustment.
http://www.r6messagenet.com/forums/r6-maintenance-technical/158635-2003-r6-idle-problem.html
Help high idle
Jun 13, 2010 | 2003 Yamaha YZF-R6
Fuel pump will not quit pumping.. Major flooding
1. Dirt or other foreign matter between float valve and its seat.
2. Float valve sticking.
3. Float valve and/or valve seat worn or damaged.
4. Float misadjusted.
5. Float cracked, leaky or damaged.
6. Excessive "PUMPING" of hand throttle grip.
Project Yamaha R6 Part
Yamaha YZF 600 R6 5SL 05
May 13, 2010 | 2000 Yamaha YZF-R6
I have cracked the right side lense cover headlight on a 2007 r6. Do youknow where I can get a new lense cover as there is no damage tothe headlight itself and have been told that the assembly is 1 piece...
you may try a "skins"stick on headlight cover, it is a thick plastic cover you cut to the shape,, it wont fix the crack but will keep moisture out and stop the crack expanding, this may keep you riding until you can find a secondhand one, cheaper than new. try autobarn or other accessory speed shops for the skins
Apr 12, 2010 | 2007 Yamaha YZF-R6
Cracked frame
Mostly depending on prescisely where it is and which way it is running, if it is along a seam it will be more lkely easily repairable, either way you will probably need to strip the frame and take it to an engineering/boiler making workshop, who may not want to do it for liability reasons and at best give you no guarentees, ultimately it would need xray to detect where the subliminal fault that preceded the crack begins and ends so as to arrest it thouroughly, and any others.
Oct 31, 2009 | 2000 Yamaha YZF-R6
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
