Question about Philips WACS700 Shelf System
The mother unit will not come out of booting up stage no matter how long you leave it
    Problem Solver:
  • 11 Answers
Usually means the hard drive is dead, Philips have some nominated service centres who will sort, I also had a double capacity fitted when mine died
Posted on Mar 08, 2014
We have bought a home with the wite rodgers thermostat 1f85-275 it doesn't seem to be working. on the top right of the screen it states 1&2 stages? anyway, help would be appriciated
Hi, this thermostat is for central heat and air systems that have more then 1 stage of heating or cooling. For example, your unit may have 2 stages of cooling, as in 2 compressors, or 1 stage of cooling and 2 stages of heating as used in commercial heat pumps. This is a multi-stage heat pump thermostat. It may be just a matter of programming the stat. If you can find a manual on it, this would help. If you open the cover, it should have directions on how to program it.Make sure you have power to everything, check all breakers to see if they may be shut of, even if you have a display, doesn't mean you have high voltage to run the unit. Make sure fan is in auto, and on heat or cool, and temperature set for it to come on. Please keep me posted.
Sincerely,
Shastalaker7
A/C, Heating Contractor
PS Your unit has 1 stage of cooling, and 2 stages of heating.
Nov 05, 2010 | Heating & Cooling
Dear Sir/Madam, During installation of Microsoft XP,my screen show a message BIOS system outdated and i need to contact the nearest vendor and get the update. The message also give suggestion to push...
Azlan,
i need to know what operating system you have and model of the computer
if you boot-up the computer, press F2 or F11 , to get to BIOS . Once you get there, record the BIOS version and let me know this information please..i am sure i can figure this out for you
Nov 03, 2010 | Computers & Internet
My AVR-2106 receiver will only stay on for a few seconds before clicking off. We have disconnected all components and speakers from unit to eliminate short circuit/wire problems and still with only power...
Hi amy, Your vivid description of the problem confirms that the protect circuit is cutting off the amp on detection of a high current drain. The possible fault is the failure of the Audio Power Output Mosfets. You will need to remove the mother board to test the stage and confirm to replace one of the stages.
The second possibility is that the protect circuit by itselff could be defective and cause a faulty bias to trigger the cut off. This must be checked by a stage by stage Voltage check.
Since the removal of the mother board requires some experience so as not to tamper the set , you must decide on the course of action.
The other option I can suggest is to call up the Denon call centre and check up the nearrest service centre, send and receive the set to them by courier after confirming the fault and estimated costs. If this justifies then it must be thought of.
I am sure you can search for one as I am not sure the place of your residence... try a search on the web for Denon service support with your location/city.
I hope my advice helps but please open the cover to have a look inside for visible damages.
Good day
Aug 19, 2010 | Denon AVR-2106 Receiver
Motorola MC9090 G oes not cold boot.
I've found this method works best especially on Window Mobile versions, windows CE does not seem to have the problem.
  1. Have the battery inserted,
  2. Remove the battery so its at the first stage of removal,
  3. Hold down the On/Off button and trigger,
  4. Insert the battery, still with On/Off button and trigger held,
  5. As soon as the amber light flashes release the On/Off button and trigger.
  6. Unit will attempt to cold boot and then warm boot,
  7. If it works then it will boot through to the Windows Splash screen or desktop.
  8. If it fails and continuously warm boots, remove the battery fully as soon as it cycles a warm boot.
  9. The terminal will not switch off at this stage and will completely drain the backup battery and RAM, giving you a complete clean cold boot
  10. Leave the battery out fro 20 minutes.
  11. Power on and see how far you get.
If it still fails after this I would suggest a complete re-flash of the system. Please post a follow up question on how to do this.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Jun 06, 2010 | Zebra Symbol Technologies MC909X-G Series...
I'vefound this method works best especially on Window Mobile versions, windows CEdoes not seem to have the problem.
If it stillfails after this I would suggest a complete re-flash of the system. Please posta follow up question on how to do this.
Hopethis helps.
Ifyou need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com orTEL 01202 620955
Jun 06, 2010 | Symbol Motorola MC909X-G Series Portable...
CYLINDER HEAD TORQUE SETTINGS BMW 318TI THANKS
hi this has to be done in 3 stages, leaving 20 to 30 minutes between tightening's they are as follows..
stage 1: 30Nm leave 30 minutes stage 2: 90 degrees turn leave 20 minutes stage 3: 90 degrees turn leave 20 minutes
you have to leave them this length of time so as not to put to much strain on the head in one go...hope this helps please vote thanks
Mar 06, 2010 | 1997 BMW 318
Hp 873n desktop opened case to clean, was very dirty (alot of dust bunnys) unpluged and took outside to blow it out with canned air cleaned all fans and entire case pluged in all and fired it off and got 1...
Wow...did you use a vacume anyware near the mother board? the static on the end of a vacume hose is REALLY BAD NEWS TO A MOTHER BOARD.
Try to reseat all cables and plug's. try to boot again.
If that doesn't work try this.
Remove all PCI DEVICES. Try to boot with just the power cable... bare bone mother board....will it post?
If not remove the board from the case...try booting again...if she doesn't boot ast this point , the board took a static hit...she's toast...sry..:)
Please leave feed back
Thanks
Feb 23, 2010 | HP Media Center PC 873n (P9875A#ABA) PC...
Computer locks up
Do a search for a good system cleaner of hacks viruses and malware and should do this all in one simple run tool.
You need to look for COMBIFIX.exe 3.39mb when you run it turn off all antivirus checkers and leave on your internet in the first stages of the setup.
This will sort your system and speed it up too. This must be done at your own risk, one thing i have noted it does is to provide a recovery option at boot and it changes your internet options back to internet explorer.
AndystUK
Nov 08, 2009 | Microsoft Windows XP Professional With...
No dash
you must first get the ULTIMATE ARMOR LEG PART. (in chill penguins stage.) then press circle. if that doesnt work then the problem is with the button on your unit.
Feb 03, 2009 | Capcom MegaMan: Maverick Hunter X for PSP
Philips WACS700 Shelf System Logo
124 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
