Question about Audiovox - Pursuit - PRO-9233 - Upgrade Factory Keyless Entry To Alarm Secu
Pursuit Series PRO9232A Keyless Entry Alarm System not working
FOB not working (new battery), bypass/valet LED not lit, no horn, no programing!
Tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 | Car Audio & Video
Tip
How to get a Viper alarm out of valet mode
Exiting Valet Mode with Key Fob:
1. Open the entry door.
2. Press the lock button.
3. Press the unlock button.
4. Press the lock button again.
5. Ensure the red LED is a steady glow.
Exiting Valet Mode with Valet Button:
1. Turn the ignition ON.
2. Turn the ignition OFF.
3. Press and hold the Valet/Program button for 10 seconds.
4. Ensure the red LED is a steady glow.
on Apr 14, 2010 | Vehicle Parts & Accessories
Keyless entry remote no longer works and alarm led light located between the front seats is no longer on or can be alarmed.
I had to huy a new fob key for my car. If i didnt i cudnt even start my car. If for a dodge charger. Actually selling it. Person wud just have to reprogram it to there car... so u will probably have to get new keyless remote and have programmed to your car.. mine was almost 400. Dollars
Jul 29, 2015 | 1995 Nissan Altima
Where is the valet switch for a 2004 dodge ram 1500
valet switch?????????????????
When the anti theft system was created,the dealers forgot to tell the new car buyers about how much the fob matters to the vehicle,without it,owners are stuck,your anti theft device is activated,you need to lock and unlock your doors a couple times with the key fob,not the key,and then you need to put the key in the ignition and start it,if you dont have your key fob,call your car dealer to get a new one,they are programmed for each car only,you cannot bypass it.if you lost your fob or never had it,whatever,you need to have the exact fob that came with that car from the factory,the key and fob have a chip in them that only go to that certain car,if you do not have it,then you need to buy a new one from the dealer or ebay and then you need to contact your dealer about programming the fob to your car,you might not have to have it towed if they have the documents from the car,the only other way is to get a junk car,with the steering column,key,fob and all computer boxes and door locks and switch them,i just did that with a 98 dodge dakota,and it works.
Mar 29, 2015 | 2004 Dodge Ram 1500
Tip
How to get a Viper alarm into valet mode
Entering Valet Mode with Key Fob:
Entering Valet Mode with Valet Button:
How can I get instrction book for reprograming avital remote starter for rpn 7111l
If you are looking to sync the remote key fob to the remote starter:
Remote programming 1. Turn key to the ON position 2. Within 5 seconds, press and release Valet button one time. 3. Within 5 seconds, press and hold the Valet button. The LED will flash one time and the horn honks to confirm entry into remote programming. 4. Press the button on the remote control. 5. The horn honks to confirm the remote has been programmed. 6. Release the Valet button, and turn the key to the Off position. 7. The horn sounds one long honk to confirm that remote programming has been exited. The programming routine exits if any of the following occurs: • The ignition is turned off • There is no activity for 30 seconds • The Valet button is pressed too many times
Mar 01, 2015 | Avital Vehicle Parts & Accessories
I am trying to program a new fob for my Alert starter and cannot find the Valet switch. I have an 04 Jeep Liberty.
i'm not sure that there is a valet switch , follow this u-tube link to see procedure for programming new fob , i hope it's the same as your system
How To Program New Jeep Liberty Remote
Jun 05, 2014 | Cars & Trucks
Audiovox - Pursuit - PRO-9233 - Upgrade Factory Keyless Entry To Alarm Secu Logo
97 people viewed this question
Top PROWAX Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a PROWAX Vehicle Part and Accessory Expert? Answer questions, earn points and help others
