Question about Qb Labs Gray Away Root Concealer - Medium Brown to Dark Blonde
Ugly build up With the use of QB labs product, GREYAWAY
Build up of greyaway product
  • Roger Rouleau
    Roger Rouleau Feb 08, 2014
    Hi Roger Rouleau, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Roger Rouleau
    Greyaway is great for disguising my small patches of thinning/balding on my scalp, but I use it to actually color the scalp. After the product dries and I comb my hair, I need to use hair spray to keep the hair in place. Unfortunately, this practice seems to create a "build-up" of crud. How can I safely and effectively remove this "build-up"?
Greyaway is great for disguising my small patches of thinning/balding on my scalp, but I use it to actually color the scalp. After the product dries and I comb my hair, I need to use hair spray to keep the...
You need to use a clarifying shampoo to remove excess build up. You can also make your own. In a small seperate bottle, add a teaspoon of baking soda to every 2 ounces of shampoo. Small batches work best.
Feb 08, 2014 | Qb Labs Gray Away Root Concealer - Medium...
New laptop with updated QuickBooks Pro 2014 - transfer older QB on PC
data transfer cable from best buy or walmart runs about 30 dollars
Jan 24, 2014 | Computers & Internet
Recently purchased a new computer with window 7. Ouickbooks 2008 installed ok but within a week I got the message a file within the program should be replaced. I tried to uninstall QB 2008 but it will not...
Welcome to Fixya
To uninstall the QB 2008 program. Click start menu then click control panel. Go to program and features icon and search the quickbooks 2008 program. Highlight it and click uninstall on top. Wait until the program will be uninstalled to your system.
Thank you for using FIxya!
Sep 04, 2011 | Intuit QuickBooks Pro 2008: Windows
I get an error when I'm closing Quickbooks Simple Start, The instruction at "0x56461f49" referenced memory at "0x036c4360". The memory could not be "read". Do you know what this means and how to fix it?
Assuming you have Windows XP, please follow these steps:
1. update QB . To update QB,launch Quickbooks and then go to Help>Update QuickBooks. In the windows, click UPDATE NOW.
2. Then go to Start>Control Panel>Add/Remove Programs. Then check mark SHOW UPDATES.
Then find Microsoft .NET framework 2.0 SP1 or SP2. Find update KB976576 or KB576976 and remove it.
3. Restart your computer and then launch and close QB.
ISSUE WILL GET FIXED
In any situation, this issue will never ever effect your QB data file.
If issue remains, reply with QB version and Windows Version?
Jul 10, 2010 | Intuit QuickBooks Simple Start Edition...
Error 7149 Quickbooks
Thanks, that worked! I first spent a half-hour on the phone with the non-tech support at Intuit and he walked me through that download. What the download does is update your original QB 2005 RC1 version to the RC9 version ("Release Candidate") where they've fixed some things (such as the Flash 7 install problem). Here's what we did:
1.) Removed Flash ActiveX 9 in Add/Remove Programs
2.) Downloaded webpatch from QB site (start here: http://www.quickbooks.com/Help...
3.) Closed QB (couldn't open it anyway)
4.) Installed patch.
5.) Restarted computer.
6.) QB worked!
Thanks for your postings. I hope this helps.
Thanks.
May 07, 2010 | Intuit QuickBooks: Pro 2005 for PC
Convert QB POS to QB Premier Accountant
a) If you previously syncronized POS 2008 with the financial product, then no, you cannot syncronize the data again, unless you tag each transaction (for the whole years) as "unsent".
b) If you have never syncronized POS 2008 with any QuickBooks Financial product, then yes, you can syncronize/download the data into QB 2009 Accountant Edition.
Before you do either: Make sure you do not already have 2008 data in your file.
Jan 14, 2010 | Intuit QuickBooks Premier Accountant...
Error message Library not registered
I got the message "Line 25: Library not registered" after uninstalling QuickBooks Pro 2009 and trying to run my old version of QB Pro 2006.
(I had installed 2009 version to upgrade my QB2006 Pro version but got into problems with multicurrency support not being supported in the Canadian QB Pro 2009.)
Fix is VERY easy and I think it applies to anyone trying to run an older version of QB Pro after uninstalling a newer version.
Fix is to find the file "reboot.bat" located in the program files associated with the older QB version.
In my case it was found in "C:/Program Files\Intuit\QuickBooks Pro" folder.
Just double click on the file to run it. This file tells the system where parts of the QB program are located including the DLL libraries it needs. After running this file you should be able to run your old QB version OK. No rebooting necessary.
May 08, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Upgrading from Quickbooks Pro 2003 to Quickbooks 2009
I would not open up the company file in 2009. Open your 2003 Quickbooks, make a backup and then restore the back up in 2009. If you do run into problems you might want to upgrade into 2006 and then to 2009. (you will need to find someone who can do this for you if you don't have a 2006 version. I can help you with that if you need it
Jan 21, 2009 | Intuit QuickBooks Premier: Accountant...
Qb Labs Gray Away Root Concealer - Medium Brown to Dark Blonde Logo
88 people viewed this question
Top Qb Labs Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Qb Labs Health and Beauty Expert? Answer questions, earn points and help others
