Question about Galaxy Radios DX-44V 40-Channels Base CB Radio
Where is the modulation diode in a cobra 89xlr
    Genius:
  • Galaxy Radios Master
  • 1,795 Answers
The modulation limiter is d12 and d13.If you intend on cutting it to give more modulation don't because all you greate is a radio that splashes every channel.
Posted on Aug 10, 2014
Working on a 25ltd classic that was wired backwards and wouldn't power up. I changed diode and it lives again. 10 watts output no modulation.
10 watts is illegal. Modulation circuits didn't fare so well. A lot of components fry when you reverse polarity.
Dec 31, 2015 | Cobra 25LTD "Classic" CB Radio
How do I adjust modulation on cobra 25 wx nw st?
The Modulation adjustment is VR5, or you can cut D9, though I do not recommend completely disabling the AMC circuit. If VR5 does not have enough range, lift the banded end of D9 & solder a 1K-ohm resistor in series with the diode, then adjust for 100% modulation or to where the AMC circuit just starts to limit modulation.
Mar 09, 2014 | Cobra 25 WX NW ST CLASSIC CB RADIO WITH...
My radio 148gtl d has low modulation
Mar 04, 2014 | Cobra 148GTL AM/Single Sideband CB Radio -...
Cobra 29 wx nw st how to increment modulation
Clip D-11 .diode 11 .this is the modulation limiter .
Jan 30, 2014 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 ltd classic no modulation
check VR4 to make sure it isn't closed . Check D 11 to make sure it isn't clipped . Turn VR 4 clockwise till it stops then back it off a little .If D 11 is clipped replace it with another diode then try it again. If it doesn't work it could be your final or your driver so replace both..
Jan 15, 2014 | Cobra 25 LTD 40-Channels Base CB Radio
Looking for cobra 89xlr transistor. 176-048-9-002 (2SC458-6)TR14, and a diode 151-088-9-001(IS2473)D14
Try some one like MCM electronics, you have the generic numbers right here for those parts.
Dec 06, 2012 | Radio Communications
I want to know what to cut or remove and tune to get maximum modulation and output out of my cobra 18 wx st ll thanks
VR2 is the modulation adjustment. I can't remember which way you turn it to get more modulation. It's usually to the left.
Hook up a watt meter. Turn it one way, and check it. If it is up a lot you got it. If its lower just turn it the other way.
Put a jumper in place of the diode at D21 which will increase voltage to the final and give you a little bit more. not much more you can do to this radio. It's the worst radio Cobra ever made. I wouldn't waste my time. I would use that one as a door stop and go get a cobra 29. You will see more out of it.
Oct 25, 2010 | Cobra 18 WX ST II 40-Channels Base CB...
Cobra 148 gtl b no recieve
make sure that the rf gain is turned up all the way.Check diodes D-12&D-13.
Jan 08, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 29 LTD CLASSIC C.B.
You should not cut the modulation diode, you should adjust the potentiometer VR-4 for full modulation. By cutting the diode, you risk over modulating. By turning up the pot, you can correct for an over modulation.
If you are still insistent on cutting the modulation limiter, it is D11, located directly in front of VR4 and C73. Looking at the radio from the front to back, it is in the right corner, apx 2 1/4" from the back and 2 3/8" from the right side.
Dean Pitts
Rollin CBs
Nov 17, 2008 | Radio Communications
Galaxy Radios DX-44V 40-Channels Base CB Radio Logo
61 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
