Question about Health-O-Meter Healthometer 845kl Digital Floor Scale
Will not turn on
Replace battery & still will not turn om
Parasitic draw on battery how to check on car with all those electronics still live with ignition key out of ignition lock
You will be able to help diagnose the problem by pulling fuses. Take a volt meter and put it to oms. Disconnect the positive battery cable. Put one end on the positive battery termanal and the other on the cable. Note the oms. Now, pull one fuze at a time until the oms drop considerably lower than before you pulled the fuzes. Thats the system that is drawing the power. Once you know the system you can track it down further. It could also be your altrenator. Disconnect it too and measure the oms before and after. take your time and do one system at a time noting the oms before and the oms after. My quickest guess it it is either your altrenator or your radio. Please note, you will have some "draw" no matter what because your clock radio or door lights will draw power. If you want to see this, test the oms with the doors closed and then test with the door open. The oms number will be higher with the door open.
If you don't have a volt meter, you can always test one fuze at a time over night. That would take considerably longer tho.
Dec 07, 2010 | 1994 Lexus LS 400
How do i remove replace battery in my dell XPS 1530 laptop?
Please refer to the owner's manual for this laptop model at the following link:
http://support.dell.com/support/edocs/systems/xpsM1530/en/OM/PDF/RU335A02MR.pdf
Page 48 of this PDF file explains how to replace the battery.
Nov 23, 2010 | Computers & Internet
I need a screw cap for battery container on OM 2
I can supply new OM-2S battery cap at www.zuiko.com. John
Sep 06, 2010 | Olympus OM2 SPOT/PROGRAM OM2SP SPARES OR...
Need to replace the battery in a dell inspiron 5100
To replace the battery, see page 44 in the manual:
http://support.dell.com/support/edocs/systems/ins5100/en/i5100-om.pdf
Purchase from here:
http://tinyurl.com/menmmb
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 12, 2009 | Dell Inspiron 5100 Notebook
Olympus om-4ti makes a screatching noise and stops working
The biggest clue is that you're having to take action to save the batteries. High battery consumption is a a classic sign of a faulty circuit board in this camera. Unlike most regular OM-4's, the OM-4ti generally had an improved circuit board fitted from new which was made available as a warranty repair item on regular OM4's, but you may have an early one.
The faulty circuit board manifests in other ways, most commonly the dead display/non functioning shutter except for the mechanical default speed. I've heard of the screeching fault as part of this problem but have not personally encountered it.
The fault is irrepairable as replacement boards are fashioned of finest unobtanium; the same faults affect the OM-2sp as well. This is exactly why both cameras are now available far more cheaply as used buys: potential buyers who know these models are aware that they're taking a gamble.
There is a revision marking on the "good" boards but it's largely academic. Anyone with a "good" OM4 rarely sells it, and even the revised boards are old enough to have started deteriorating by now.
May 06, 2009 | Olympus OM-4TI 35mm SLR Camera
I cant turn off my light meter om my v3800n 35mm camera without taking the batteries out. Is there a way to turn the meter off? Or do I have to take the batteries out every time?
Hello...there is most probably a defective switch on the camera...If you are facing the front of the camera, on the camera body, to the right if the lens is the meter button.(near the flash pc socket) Also, you can check the condition of the batteries by pressing the shutter button half way down. If you see a red or green light, the batteries are good. If not, replace them *both* with silver oxide.
Mar 07, 2009 | Vivitar V3800N 35mm SLR Camera
Replace the battery of hp
Contact : Amar
Mobile : 9876101234 [Send Free SMS] red-arrow-down.gif Enter Your Message.
[Max Limit 100] Your Name
Your 10 Digit Mobile No.
Enter Verification Code 3bef54
Phone : 9811137536
Address : 2879 Sant Nagar Main Road Rani Bagh Near M2K Pitampura New Delhi
website : http://www.beyondlaptops.om
Feb 04, 2009 | HP Compaq Presario V2000 Notebook
Health-O-Meter Healthometer 845kl Digital Floor Scale Logo
Top Health-O-Meter Health & Beauty Experts
creative_lac
Level 1 Expert
Shehu Pro
Shehu Pro
Red721
Level 1 Expert
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
