Hang update bios
I wanted to update my laptop bios(asus n46) with WinFlash, but it failed and then I restarted my laptop but the laptop hanged and even I can't turn off the laptop, I don't know what to do? please help me
    New Friend:
  • 87 Answers
You have to remove the bios chip from the mainboard and flash it with the right bios version out side the laptop.
Posted on Feb 08, 2014
4 Suggested Answers
hokuwho
  • 306 Answers
SOURCE: needs help to recover crashed asus r2h bios
You need to put the battery back in, try to find an IDE floppy drive to use and if the new bios version hangs then download the old BIOS and reinstall that -a computer that hangs is not a successful install or the upgrade is wrong. Pulling the battery doesn't revert to the old BIOS, just default settings for the BIOS installed. Using a USB floppy for this is not a good idea as the usb drivers must load -might as well use a thumb drive if this is a laptop. For a desktop stick with the basic IDE floppy drive. Best of luck, Steve Medley
Posted on Nov 08, 2008
registerthis
  • 78 Answers
SOURCE: intel DG31PR mother board hanged after bios update
Try this and read the "Instructions for Recovery BIOS Updates" section.
http://downloadmirror.intel.com/17084/eng/BIOS%20Update%20Readme.pdf
Good luck.
Posted on Nov 27, 2008
SOURCE: i updated the bios of my ASUS P5KPL-AM SE
your bios driver is likely to be faulty.
so download a valid driver then update your bios again.
if it doesn't work, intercept all of cables of your PC case and even power cable of your monitor.
evolve battery of bios then wait for 15 minutes then connect all of cables and try turning on your pc:
1- with battrey of bios
2- without battery of bios
it should work.
Posted on Jan 08, 2011
Asus f3j bios mod for upgraded ram
Not sure what you are asking about. Asus site says the motherboard will take DDR2 533/667MHz SDRAM, 2x SO-DIMM socket expandable to 2GB
Which means DDR2 533mhz 1 gig per slot total 2gig
or DDR2 667mhz 1 gig per slot total 2 gig
To enter BIOs press F2 at boot up, but no setting should need to be changed.
They do not have a BIOs update for increasing the memory limits.
BIOs upgrades from first to current are.
BIOS 304
Update new CPU Microcode
System plays wave file and causes garbage sound.
BIOS 305
To fix system cannot do battery pre-charge process when an unknown/failure battery insert.
Support Intel Extend ID CPU:Merom Celeron 530 CPU.
BIOS 306
BIOS 307
Fix System hang at ASUS LOGO on SATA HDD with factory recovery image
Last upgrade date is 2008 7 14
Mar 14, 2014 | ASUS F3Jc Notebook
Save not cmos on mainboard asus p4p800s-x chek batry&clear cmos but not resolv save not cmose
ASUS CrashFree BIOS2
The CrashFree BIOS 2 feature now includes the BIOS auto-recovery function in a support CD.
Users can reboot their system through the support CD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional R
C.P.R.(CPU Parameter Recall)
When the system hangs due to overclocking failure, there is no need to open the case to clear CMOS data. Just simply restart the system, the BIOS would show the previous setting and then users can amend the CPU setting again.
ASUS EZ Flash
With ASUS EZ Flash, you can update BIOS before entering operating system. No more DOS-based flash utility and bootable diskette required.
hope this helps you
Mar 03, 2011 | ASUS P4P800S-X (610839118175) Motherboard
Why my asus p5kpl am se motherboard hanged after 10 mintues? Processor 2.8 celeron & Ram1 gb ddr2 800
It's difiicult to diagnose your problem, because It can be produced by a lot of circumstances. Update your drivers with the official asus drivers. You can download it from here-also update your bios-:
http://www.asus.com/Search.aspx?SearchKey=p5kpl
First of all check the memory ram, download memtest from here:
http://www.memtest86.com/
Run that program to verify if the memory is ok. The next step should be a temperature test. Maybe your system gets overheat, hanging after a critical temperature. Run Prime95, you can download it from here:
http://files.extremeoverclocking.com/file.php?f=103
Run prime95 for 5 minutes, if your system hangs up during that time, your problem is the temperature-check the fans are running and clean the computer.
If the problem persists, you motherboard should be replaced.
Feb 12, 2011 | ASUS P5KPL-AM SE Motherboard
Laptop gives no response after reboot/restart
how old is the laptop
if it has a disc hard drive it could be that the motor in the hard drive is failing
go into device manager and do a systems check
Apr 03, 2017 | Toshiba Computers & Internet
I have a GA-P35-ds3l mobo that hangs at boot for
Had a similar problem. Eventually my SATA drive failed. Had to rplace & re-install. Now boots fine. Suggest you try another boot drive to see if you have a similar problem.
Sep 10, 2009 | Gigabyte GA-P35-DS3L Motherboard
Message from asus live update: please install asus winflash first if you want to update bios. my nb asus f3jp
Asus liveupdate, from everything Ive read, is very unreliable... Dont try to rely on it, try to go to the asus website if you need a bios update and take care of it there. theyll have read me's on how to do it-- it's not that hard, but you should have a good reason to update the bios as if you do it wrong, you could be in more trouble than you need.
Jan 23, 2009 | Shuttle XPC SD32G2 Barebone
When i use vista & listen any song then it get hang and shows
Do you install a driver from CD that comes with your Motherboard? Vista CD/DVD Driver Pact creates such problem. For Vista drivers you can directly download from internet (The best Drivers/uptodate)
When you connect to internet Windows Update will automaticly download the drivers!
Best Luck!
Jan 23, 2009 | ASUS P5PE-VM Motherboard
Needs help to recover crashed asus r2h bios
Nov 07, 2008 | Computers & Internet
Motherboard_prob
just check is the processor fan is running or not then try with new ram,power supply,
Jul 21, 2008 | ASUS Computers & Internet
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
