Question about Health-O-Meter Healthometer 845kl Digital Floor Scale
Screen would not light up. Replace battery & still no screen
Turn phone on and phone lights up (screen & keypad) but no LCD display (just a white screen). To turn off have to remove battery.
It sounds like you might have gotten something in your phone or something broke inside the phone so you're going to have to replace it.
Mar 23, 2011 | Nokia 1661 Cell Phone
I have a toshiba laptop a3056872...on a friends pc now....when i go to turn it on..all the lights come on....the page tthat says toshiba innovation....hit f2 or f12....it doesnt go any further i have a...
1. Remove the battery & switch on the PC in AC mode.
2. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
3. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
4. If still no display, connect an external monitor, check if display is comming.
5. If Display is coming then your LCD is faulty and need to replace.
Aug 23, 2010 | Computers & Internet
Have a acer aspire 5520,it has developed several problems,1, will often freeze on full screen mode,have to shut it down and restart,2, will keep on shutting down after battery light starts flashing,will...
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Acer Aspire 5520-5908 Notebook
Blank screen when turned on, then there are 2 lights that flash they both have a lock symbol before them one is with an A and the other is with a 1. Everything else lights up but screen is just blank/black
follow these steps & ur issue might get resolved(80% chances):
turn off ur notebook-->take out the battery-->disconnect the charger if its connected to the notebook-->now press & hold the power key for atleast 20 seconds, remember that u have to press & hold the power key & dont release the power key till 20 seconds are over--> & ensure that the notebook is not connected to any power source while u r performing this step niether the battery nor the charger--> also there shouldn't be any peripherals connected to the notebook-->once 20 seconds are over & u have released the power key-->connect the battery & the charger back to the notebook & now try to turn on the notebook-->u might not get a blank screen & ur issue might get resolved....(This whole step is known as power drain & it is done to remove the extra static electricity which sometimes get stored in the notebook & gives a blank screen in return.)
Jul 08, 2010 | HP EliteBook 6930p Notebook PC
Red light comes on and screen goes black shuts off and then on
Your BB mobile Battery is empty , charge your battery or replace the battery
Best Regards & Thanks
Akhtar Mohammad Kalim
Mar 30, 2010 | RIM BlackBerry Pearl 8100
Laptop will not power on. I push power and all lights power up then sounds like it will power up then fizzles out and doesn't turn on
The cable for the back light inverter board may have come off on the mother board side or on the screen side.
2) Failed inverter board.
3) Failed lamp.
This place will show you what the inverter board looks like: http://www.insidemylaptop.com/how-to-remove-inverter-and-replace-lcd-screen-in-compaq-presario-m2000-laptop/
Mar 30, 2010 | Gateway MD2614u Notebook
Parking lights coming on by themselves
the switch is bad please replace same
Jul 30, 2009 | 1996 Chrysler Town & Country
How to remove thermostat cover to replace
the cover pulls off if it has a green screen then most likely takes batteries if does not light up then no batteries with a small piece of insulated wire jump from green to red if indoor fan does not come on then transformer bad
May 15, 2009 | Honeywell Programmable Thermostat Heater
Health-O-Meter Healthometer 845kl Digital Floor Scale Logo
42 people viewed this question
Top Health-O-Meter Health & Beauty Experts
Shehu Pro
Shehu Pro
Red721
Level 1 Expert
richie46
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
