Wifi do not connect shows network not in range
SOURCE: HTC Viva and WIFI Problem Connection
Hello, wifi is a sort of WLAN conection. you need a wireless router to be able to use wifi. there are two ways to connect to the internet on the touch viva. 1st way is by the sim card and that costs you a lot of money!!! the other way is by a wlan router, you can access to the internet as long as you want is you have a flatrate. My good tipp: switch off the gprs connection, it will only cost you a lot of money. you will still be able to make phone calls. Ilost about 60$ (i mean it!) by trying to access to the internet by gprs.
SOURCE: HTC Hero disconnects from network!
maybe orange dont have a large area of coverage on your city/town. try using a wi-fi connection with your home wirelless network, and if you have same problem, try reset factory default.
SOURCE: On my HTC hero, when trying to connect to mobile
to connect on a mobile network you neet to be a data plan subscriber with that network, if you try conect with your wirelless home network, you must conect via wi-fi. its basicly very simple to follow, chose your network ssid (name), connect type ssid network password (you must have that saved on your primary computer connected to your router, on my docs) hope that helps.
SOURCE: the gps on my htc sensation 4g doesn't work
First, make sure that your GPS issue is not a settings issue. Try going to settings > Location & Security > Make sure "Use GPS satellites" is checked.
If that does not fix your issue, restart the phone, retry the above process and try it again.
If all else fails, your GPS module and/or software is broken or corrupted. Contact your service provider for a warranty replacement.
When on Disk drive mode, you will not be able to use apps on HTC Sensation XL with Beats Audio that access the storage such asCamera.
HTC SyncSelect this option to synchronize contacts, calendar, and other information between your computer and HTC Sensation XL with Beats Audio.USB tetheringWhen you do not have an Internet connection on your computer, you can select this mode to share the mobile data connection of HTC Sensation XL with Beats Audio with your computer.Internet pass-throughIf you don't have a data plan or you don't have access to a Wi-Fi network, you can select this mode to share your computer's Internet connection with HTC Sensation XL with Beats Audio.
