Question about Milnor 02-03426 - Washer
Indicating axial probe fault - Milnor 02-03426 - Washer
02 impala back turn singles blink fast, when the hazards are on they blink normal but nothing blinks in the front changed all the bulbs the hazard and turn single switch put new fuses in help
Use a volt meter or trouble light, to test for voltage at the front lights, remove the bulb,turn ignition on, probe from the center of the bulb holder and to the side of the bulb holder must be battery voltage, if not probe from center of bulb holder to metal of car body, if there is now voltage the light has a bad earth, if still no voltage there is fault in the wiring from the lights to the indicator switch, or the indicator switch is at fault.
Apr 03, 2016 | Cars & Trucks
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Temperature control keeps going down. Replaced the Temperature probe, replaced axial fans. Contactor works but cant get no power from board to close contactor. This second board I have replaced.
In a cold oven the resistance of the temp probe should be approx 10k ohms. If the control has the control knob separate from the control board, as in a separate potentiometer then I would suspect that as the problem. You shouldn't lose 2 control boards in a short amount of time.
Sep 25, 2013 | Blodgett ZEPHAIRE E DBL Double-Deck...
I have a F1 code how do I fix it?
The "F1" fault code is indicating a shorted keypad, electronic oven control board failure or the oven sensor probe (RTD) may have gone bad. It will either have a bad oven sensor probe (RTD) or a failed Electronic Oven Control (EOC) board.
Jan 24, 2011 | Frigidaire FEF365AS Electric Kitchen Range
Low coolant indicator light is stuck on. How can
the coolant sensor switch on the radiator is at fault. simply disconnect the connector from the switch
May 09, 2010 | 1990 Pontiac Bonneville
My oven displays error f31. It beeps and when I press clear the beeping stops. But if I try and set the temp it reverts back to f31
The F31 fault code indicates a problem with the oven temperature sensor probe. The temperature probe is secured in the top of the inside back wall of the oven. Unplug the range to disconnect electrical power. Open the oven door and remove the racks. Remove the screws that secure the oven temperature sensor probe in the back wall of the oven. Carefully pull the sensor into the oven until you get to the wire harness disconnect plug. Unplug the sensor probe. Do not let the wire harness **** back through the opening in the back of the oven. Check the resistance of the probe with a volt/ohm meter. At room temperature, you should measure about 1100 ohms of resistance. Since you are getting the F31 fault code, you will not likely measure this resistance. If the resistance is bad, replacing the oven temperature sensor probe .This should fix your problem. You can order this part from the www.appliancehelponline.com If the resistance of the temperature probe is normal (1100 ohms), then I recommend that you access the electronic oven control board in the console (with the range still unplugged ). Remove the upper back panel. Pull the P5 connector on the control board and measure the resistance through the purple wires (pins 12 and 13 as shown below) to check the resistance of the temperature probe through the circuit that connects to the board. If the resistance is drastically different than the 1100 ohms measured at the probe, then the wire harness is bad and will need to be replaced. If you measure the proper resistance through this wiring harness at the control board and the connections are good, then the electronic oven control board will need to be replaced.
Mar 23, 2010 | Ovens
Oven code e1 f4
HI. This code will indicate that there is a fault within the meat probe device.
The Problem could be with the probe, the receptacle, or probe circuit. Check the probe for faults. Look for pinched wire. Look for condensation or contamination on the probe receptacle. Replace probe if all else checks out ok.
Jan 08, 2010 | Whirlpool Ovens
When turning on oven a f3 keeps showing up
  • The F3 fault code is indicating an open oven temperature sensor probe or an open oven temperature sensor circuit.
  • The oven sensor probe will need to be removed from inside the oven cavity and tested with an ohm meter. The oven sensor should have a resistance of 1100 ohms at room temperature. If the oven temperature sensor probe measures approximately 1100 ohms at room temperature the oven sensor is OK and the sensor circuit connections will need to checked at the oven control board.
Hope this helps .
Feel free to ask me for further help .
Dec 03, 2009 | Whirlpool Kitchen Ranges
F3 error on frigidaire built in oven, cant cook
F3 INDICATES A TEMPERATURE PROBE FAULT.CHECK RESISTANCE OF PROBE,SHOLD BE 1100 OHMS
Nov 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Starts beeping and F31 ERR flashes
Any F code error indicates a fault has been detected . Press Clear/Off to clear display and stop beeping then reprogram the oven. If the fault reoccurs record the fault number press Clear/Off and contact an authorized service agent. If you have access to the internet you can download a manual for this appliance go to www.frigidaire.com/support/support.asp
On the customer services page click on product manuals and you will be abe to download the manual and print it off.
Apr 21, 2009 | Frigidaire FEF352 Electric Kitchen Range
Milnor 02-03426 - Washer Logo
74 people viewed this question
Top Milnor Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Milnor Washing Machine Expert? Answer questions, earn points and help others
