Honeywell Model 006442-0 is this unit CSA approved ?
2 Suggested Answers
  • 42 Answers
SOURCE: No problem with unit. Is this air conditioner CSA
It's not the unit that you have to worry about for CSA or OSHA. It's how you intend to install it. You have to use the proper installation guidelines as approved by OSHA. I do know that going outside a wall or window you must have the proper bracket/frame installed outside the exterior wall to prevent it from falling on someone's head if high enough. If down low, they still have to be braced/bracketed properly to avoid injury. That's standard procedure.
http://www.osha.gov/SLTC/indoorairquality/
You need to find out what OSHA has for safety guidelines and restrictions. Also check with your local building code office to check with their pre-set guidelines. They have to be automatically in compliance with OSHA if they intend to operate guidelines for business purposes. So Call either- or both. It's not the unit you need to worry about unless it's very old. Good Luck.
Posted on Mar 10, 2011
How do I find out if the washer/dryer unit I just bought has a CSA number
Hello Marilyn;
My name is Peter. I am a retired field service appliance technician.
In the front inside the doors on both your washer and dryer you have labels. This is not where your CSA number is. This number is relative to power and electrical safety. There is a label on both your dryer and washer on the back next to your power cord connection.
Be assured, you have a CSA number. This is a standard safety code required by law.
Feb 19, 2015 | Washing Machines
Honeywell timers manual
Honeywell makes thermostat timers for HVAC unit.
Honeywell posts their manuals online.
Take thermostat off wall, to see model number located on back of unit.
For example model number might be xxxxxx2
Then google search: Honeywell xxxxxx2 .pdf manual
Jul 23, 2012 | Hardware & Accessories
No problem with unit. Is this air conditioner CSA or OSHA approved ?
Mar 10, 2011 | Maytag M3X05F2D Air Conditioner
About 4 years ago I had a LAARS MAX boiler installed with a Beckett burner and a Superstor water heater. All works well - except minor problem with burner needing to be reset occasionally. BUT when I...
First off they are not suppose to be installing a boiler that is not CSA approved. Your best bet is to contact Laars find out the real truth. I do know Laars was bought out by another company a few years ago, but the Installation company needs to stand by their product and be held accountable.
If unit is not request a new boiler or threaten talking to better business bureau Customers have rights. It also can be a liability to them.
Good luck let me know how it turns out
Jan 04, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
Aug 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
I have a Bestec atx-300-12az and i need to know which power supply harness to use on a Samsung model#HD103UJ hard drive.Thanks,Tony
Technical Details
  • Samsung Spinpoint HD103UJ 1 Terabyte SATA/300 Hard Drive General Features:
  • 1 Terabyte formatted capacity 7200 RPM spindle speed SATA/300 interface 32 MB buffer
  • 8.9 ms average seek time 4.17 ms average latency 3.5-inch form factor
  • Improved recording stability over temperature with PMR
  • Advanced dynamic FOD control for best data integrity
SATA Power3 Peripheral4 Floppy5 02 +3.3V (Orange)
03 COM (Black)
04 +5V (Red)
05 COM (Black)
06 +5V (Red)
07 COM (Black)
08 PG (Gray)
09 +5VSB (Purple)
10 +12V (White)
11 +12V (White)
12 +3.3V (Orange)
13 +3.3V (Orange)
14 -12V (Blue)
15 COM (Black)
16 PS-ON (Green)
17 COM (Black)
18 COM (Black)
19 COM (Black)
20 Blank
21 +5V (Red)
22 +5V (Red)
23 +5V (Red)
24 COM (Black)', CAPTION, 'Pin Signal (Color)', WIDTH, 150, BGCOLOR, '#000000', FGCOLOR, '#FFFFFF');" onmouseout="return nd();" href="javascript:void(0);">matx24pin.gif
atx12v.gif sata.gif drive.gif floppy.gif This ATX12V power supply is a 300W, five output unit with remote on/off, and UL, CSA, and TUV approvals. RoHS compliant. Original HP part number 5188-2625 used in many Media Center, Pavilion, and Presario computers. Also serves as upgrade for HP/Compaq part numbers 5189-3964, 5188-0131, 5187-5116, 5187-6114, 5188-0129, and 410507-001. Airflow drawn out of case into surroundings by 80mm internal fan. Built-in power status LED above AC inlent. 2 x 12 (24 pin) main board power connector. Includes two daisy chained Serial ATA connectors. Bestec model ATX-300-12Z CDR, also replaces ATX-300-12Z BC, ATX-300-12Z BD, and ATX-300-12Z CC. i trust this helps
Jul 15, 2009 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
3 beeps every few minutes
That maybe a memory beep code. Turn it off and remove and re-insert the memory modules on the mainboard.
If this doesnt work, get back to me.
Feb 13, 2009 | Apex Computer Technology Apex Power Supply...
Bernette IS60 Iron won't heat up. Light comes on indicating power source okay.
I would love to comment on this but unfortunately I am without documentation on the Bernette Irons, they aren't CSA approved and therefore a rarity to find in Canada. Call around to find a certified Bernina Technician in your area and ask if he or she would have a look, make sure they have experience as documentation for these are hard to come by.
Jun 25, 2008 | Bernina Bernette 75
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
