Help solve the error code C7760 in km 1635 copier
SOURCE: KM 1505 copier machine
click cancel+start+light then release all then press cancel.... you are now in simulation control service..... press the zoom in and out so that it will display 163.... after displaying 163 press start... the machine will restart then the code will lost.. if it return there is machine problem somewhere in the fusing unit....
Posted on Apr 25, 2008
SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
Posted on Jun 12, 2008
  • 36 Answers
SOURCE: MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Posted on Apr 09, 2010
  • 241 Answers
SOURCE: How to solve error c6020 for Kyocera KM-2035
The C6020 is a fuser error code and should be checked out by a Kyocera tech.
Posted on Jun 09, 2010
SOURCE: koyceracopier km 1635, has error c-6
Dont waste your money on replacing the fuser, just switch on the machine and enter its maintenance mode which is 1087 (dial 1087 twice) then you hit 163 and your machine will shut down and restart itself then you are Ready to Copy
Posted on Apr 08, 2011
Error code C7760 in Kyocera km 1635 copier help me
Drum type mismatch problem B The drum type is undefined.
Causes
Defective software of the engine PWB. Defective engine
Change the drum unit
Jul 10, 2017 | Kyocera Office Equipment & Supplies
C7760 in kyocera KM 1635
C7760 Description Drum type mismatch problem B The drum type is undefined. Causes Defective software of the engine PWB. Defective engine PWB.
Jul 19, 2014 | Kyocera Office Equipment & Supplies
Km 1635 code c6
error the fixing section.
open & close the convert section
& reset the fixing code
Apr 28, 2014 | Office Equipment & Supplies
Km 1635 c-3 error what is a problem
Kyocera mita km 1635-installed new drum but printing blank papers
Sep 06, 2013 | Office Equipment & Supplies
I have an error code C6 020 in my copier kyosira KM 1635. Please give me the means of this and what I can do to reslove the problem. Thanks
goto service mode by pressing 10871087. then press 163 then start 4 times.the machine will restart and wola
Jun 03, 2011 | Kyocera Copystar CS-1635 Copier
I am Having Problem with Kyocera KM 1635 with code C-6 what that mean and how we can solve that
you have a problem in the fuser/fixing section. error code should be 4 digits long to correctly identify the problem
Aug 27, 2009 | Kyocera KM-1505 Copier
145 people viewed this question
k24674
jasbo
jasbo
