Question about KitchenAid KERC507 Electric Kitchen Range
Oven temperature way too hot
After running the self clean cycle on our KitchenAid Superba KERC507HBT0 oven, the oven would not heat. I traced that problem to the thermal fuse, replaced it, and that fixed the "would not heat" problem. The problem that I am having now is that the temperature will not regulate. I checked the ohm reading on the oven temperature sensor and it is running about 1085 ohms, so that sounds about right. What else should I check as the source of this high heat?
  • 3 Answers
The ohm's on the temp sensor is adequate if measured at normal room temperature. Next check the wiring from the sensor connector to the control board for continuity. Also verify there isn't any corrosion on the connection to the board. If that is good, visually inspect the control board for burnt areas as that will be the only other component in that function. This control board is NLA but you may find one stashed in someone's old inventory.
Posted on Feb 08, 2014
4 Suggested Answers
  • 4 Answers
SOURCE: KitchenAid oven shut down during self-cleaning
I've had the same problem and have had the thermo-protector switch replaced four times. After the last time I was so ********** I wrote to the CEO at Whirpool/Kitchen Aid in Benton Harbor, MI with my complaint. Today I received a call from an extremely nice lady in his office who said that they were sending me an updated kit for repair free of charge. The part number is 9759243. She offered that this was a known problem but was limited to just one production run - my luck!
If you are having this problem with your KGSA906PSS write to the CEO at Whirlpool!
Posted on Feb 02, 2009
SOURCE: Kitchenaid Superba Gas Oven Touch Pad not working
We have a gas kitchenaid KGST307HBL9 and the touch pad is blank, but we discovered that you can still touch the buttons and it will work. (example touch bake; temperature; start). It will beep when the target temperature is reached.
Just so we don't forget and leave the oven on, we turn the oven light on as our signal. A little work, but not wanting to "fork" out the money at this time to repair.
Also, if you are handy RepairClinic.com has many items and can also answer question. We've used them for several of our appliance repairs.
Posted on Jul 02, 2009
  • 25 Answers
SOURCE: inoperable KGRE801PBS00 Kitchenaid oven
1) unplug and turn your gas valve off
2) with a #2 phillips remove all the silver screw on the back of your stove (this will make is to you can remove the stainless splashguard)
3) there are several black screw holding on a removable (stainless) panel that covers the back of the stove - your culprit (thermal fuse) is under here).
4) on the back of the oven you'll see the back of a couple of fixtures (stove light, temp sensor etc). <-- do not touch these..
5) there is another attachment (attached with black #2 robertson screws).. it has two black wires plugged into it.. this is your thermal fuse - mine has a number 8300802 on it.
I had to replace this (18bucks) from my local hardware store. Unfortunately, these stupid ovens have this part recurring so buy a few.
At your own risk - when reinstalling, slip a little cardboard between the thermal fuse sensor (stainless flat side) and the stove.. you may save a few headaches..
this repair was an easy one compared to replacing the board on this stupid oven.. (i would not recommend buying one - typical north american engineering designed to keep the repair folks working)..
i guess you need to find a different way to screw the consumer eh KitchenAid? lol
have fun
CA
Posted on Jul 22, 2009
Kerc507hbt0 oven won't heat
Chances are that the thermal fuse on the back of the oven has gone out. If you used the self clean feature and then it didn't work this is more than likely the problem. If not then it coulkd be an element that is bad or a control board oproblem.
Feb 06, 2014 | KitchenAid Architect Series KEBC107KSS...
I set my kitchenaid superba self clean oven to clean mode. It cleaned it however now I cant get the oven to work. Stove top works but oven doesn't. What can I do to fix this?
Pyrolitic mode heats up quite hot. Might have tripped the high temp cutout.
Does the oven fan work? if so >> check element
Oct 17, 2013 | Ovens
My kitchenaid superba double oven in not woring at all after the self clean cycle finished. top oven door will not open, no lights on, nothing happens when I push buttons
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 22, 2010 | KitchenAid KEBC107 Electric Single Oven
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
How do I use the self cleaning functions - kitchenaid oven
Please allow me to help you first with some background of self cleaning functions:
Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
If baking spills are not wiped up after baking, there may be some smoke during an oven cleaning cycle. It is a good idea to remove any pets from the area when running the oven's self-cleaning cycle. There have been reports of oven-heated Teflon-coated items releasing odorless fumes deadly to birds.
Self-cleaning ovens have the added benefit of more insulation, which helps the energy efficiency for regular baking. This is similar in concept to an increased R-factor for home insulation.
You will also save energy costs by using the self-cleaning cycle right after baking, to make use of the already partially heated oven.
Please check this website mentioned bellow which would give you a detailed method of how to perform it:
http://cleaning.lovetoknow.com/Self_Cleaning_Oven_Instructions
Hope this would help you .
God Bless.
Jul 05, 2009 | KitchenAid Kitchen Ranges
Jun 03, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
The door is locked
Put the unit back into a clean cycle, wait 2 minutes and then push cancel, the door should unlock
Jan 21, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Nov 11, 2008 | Ovens
OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
KitchenAid KERC507 Electric Kitchen Range Logo
54 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
