Question about Canon PIXMA MP240 All-In-One InkJet Printer
My canonpixma mg3150 has paper jammed in it and I cannot reach it how do i open the printer
SOURCE: paper jam
I had this problem the other day. I turned out that I had a small bit of polystyrene foam had got trapped just before the white plastic rollers you can see in front of the toner sponge where the cartridge head runs when you lift the lid to change ink.
I discovered it by noting that on power-up these rollers turn as if to feed paper back into the paper feeder (i.e. "backwards through the printer"), so I tried to see if I could get a sheet to feed backwards and noticed something was trying to stop the right-hand side of the paper feeding in. Soon after I noticed the bit of foam through the right-hand side slot in the white plastic section above the roller. A quick removal with small tweezers et viola!
Andy
Posted on Mar 13, 2008
SOURCE: jarry cannon
open printer cover, pull out toner cartridge, re-install cartridge, close door, it should re-boot the machine.
Posted on Sep 25, 2008
  • 1335 Answers
SOURCE: My canon multifunction printer model MP830 has a
Download the manual at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=12804#DownloadDetailAct
page 71-73 addresses how to remove an internal paper jam.
Posted on Apr 26, 2009
canontech
  • 1219 Answers
SOURCE: how do i clean roller paper feeder on canonpixma
You need to remove covers or very gently your way
Posted on Jan 12, 2010
pineworks
  • 4041 Answers
SOURCE: paper jam
gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
Paper completely jammed
Lift feed panel, then the cover. carefully pull in thedirection of normal feed onto the scan plate. Do not try to pull out from the entrance.
Mar 13, 2015 | Canon Pixma MG3150 All-In-One Color...
Canon Pixma MG3150 not printing or lifting paper from the input tray?
Please check the cartridges.Re install the cartridges properly and try.
if ink is dried refill the ink.some times will happen to new printers also.if waranty is there cary to nearest service point.
Nov 07, 2013 | Canon Pixma MG3150 All-In-One Color...
A 0 2 P flashing on my canon printer
Have you tried turning it off? If you haven't tried it after getting the paper jammed, then turn it off. Just make sure that the paper is removed.
After turning it off, unplug it from the wall outlet and from your computer. Press and hold the power button for 5-8 seconds so that you can drain the power completely.
Plug it back in the power outlet. Turn it on.
Plug it to your computer and check if you still have the same error. If the flashing lights still occur, make sure that all papers which are jammed are removed. There might be some small paper left inside your printer.
I hope this helps.
Carlo
Nov 21, 2012 | Canon Pixma MG3150 All-In-One Color...
Hello my CanonPIXMA MX410 has been working fine until yesterday It always says paper jam and I check there is no paper I dobn't know what to do please help me
Hi
Try disconnecting the printer completely from power and from the PC.
Reboot the PC.
Connect everything again.
Clear any print queues.
Make sure the paper feed tray is not filled to capacity.
Hope it helps.
Feb 23, 2012 | Samsung SCX 4200 All-In-One Laser Printer
I've got a 4 by 6 photo paper jam in my Lexmark S405 all-in-one printer.
Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Try to reach for the paper jam.
3. If paper jam can't be reached, open the printer cover to access the cartridge area. You may be able to get a better hold of the paper jam in the cartridge area.
4. Remove the paper jam and make sure not to tear or leave any torn piece of paper in the printer.
When paper jam is clear, try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark All-in-One Printer with PictBridge
PAPER JAM - CAN'T FIND THE PAPER. IS THERE A WAY TO REACH PAPER WITHIN MACHINE?
Open the printer cover and access the cartridge area. You should be able to see the paper jam. Carefully remove the paper and avoid tearing it. Any torn paper left inside the printer could cause future paper jams.
May 01, 2011 | Lexmark X5470 All-In-One InkJet Printer
Paper jam: cannot reach the paper, how do I get
This video was created for the C7280, but works the same for your printer.
Jun 10, 2009 | HP Photosmart C5180 All-In-One InkJet...
Paper jam on office jet G55 hp in a hard to reach location.
in rear of HP printers there is an access (clip on plastic plate) you should use to remove paper shads or jams. Pulling paper out from front may harm the printer. Open back and attempt removal of jam.
May 19, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
Printer
hi this is tekalign my quation is my canonPIXMA IP 1700 printer how is instoled with my compiter vista 2007 plises givme the idia how it is instold tankyou
Apr 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP240 All-In-One InkJet Printer Logo
old marine
old marine
