Question about Maytag MAH6700AWW Neptune Front-Load Washer
Replace door door wont lock
    Prodigy:
    An expert who has answered 500 questions.
  • Maytag Expert
  • 517 Answers
Check the door pin and the lock
Posted on Feb 08, 2014
2003 VW GOLF REAR door wont open
The rear door lock actuator has failed in the door locking unit this is a common problem you can manually unlock the door to replace the latch if you didn't have the deadlocking on if you cant try pressing the locking button twice so when the car is locked the flashing red light is not blinking ie off on the drivers. Doing this usually causes the faulty lock to release the dead locking so you can pull the inside handle to unlock the door.
Oct 13, 2016 | 2003 Volkswagen Golf
Door light wont come on and dor wont lock, also replaced control board with new on and burned hole in it just like original
Hi, The wax motor of the door lock is the problem that is burning up the boards, replace the redish brown wax motor in the door lock assembly
Sep 24, 2012 | Washing Machines
My driver side door wont lock
The actuator that locks the door is probably worn out. I would simply lock it manually .
If you desire to , you can replace the actuator by removing the interior trim panel and drilling the rivets holding the actuator in the door. Replace the rivets with small screw/bolt combos .
Jul 15, 2010 | 1998 Ford Crown Victoria
The driver side door locks and unlocks but it wont open at all
Looks like the lock itself has a problem in this that's why it wont open or there's something that makes the door stuck even though you lock/unlock it, It's best to replace the side door lock immediately. or better check if there's any elements that are inside the side door that makes the door jammed.
Mar 02, 2010 | 2006 Buick LaCrosse
Rear door wont unlock or sometimes wont lock
The rear door lock actuator needs to be replaced. If you have the dealer do it you will pay $300.00+. If you do it, you can do it in an hour for about $20.00. Just buy a universal actuator kit that looks similar to the one already in there from the factory. Do A Google Search on "Mazda Tribute Rear Door Lock Actuator" to find sources for them.
This is a VERY common problem on Ford Escapes and Mazda Tributes, all years. I am surprised there has not been a recall on this.
Jul 18, 2009 | 2002 Mazda Tribute
Doors will not lock
replace the actuator. wouldnt recommend doing this yourself as it requires you to tear apart the door. the dealership will do it for around 150
May 28, 2009 | 2002 Acura RSX
My volkswagon door wont lock?
the door lock or actuator that needs to be replaced Please rate my response thank you very much
Jan 30, 2009 | 1998 Volkswagen Passat
Cycle wont start then I get Error / dl
the dl code is a door lock error,open door and examine door lock assy mounted on front panel.look for a plastic push pin approx 5inches up from square lock assy.if that pin is missing,replace door lock.if pin is there,you could still have bad door lock or loose wire connected to door lock.
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine door wont open
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Jul 19, 2008 | Washing Machines
Maytag MAH6700AWW Neptune Front-Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
