Lg wm2277hw Washing machine isn't getting power. Could it be anything other than the pcb board?
    Problem Solver:
  • 14 Answers
Is there power at the wall? if so open the panel and see that power it getting to the board? if so check for loose or broken wires, there may be a fuse in there. be careful when checking for power you dont want to get a zap.
Posted on Feb 09, 2014
4 Suggested Answers
rdrsp
  • 85 Answers
SOURCE: LG model WM2277HW front load washing machine,
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
1) in my experience, sometimes this proves to be intermitent, and upon unplugging and waiting for 5 minutes does not seem to resurface again...
2)Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount.
this could prove to be very challenging to somebody who does not know what they are working with, i suggest if the problem is not intermitent, call a tech.. hope this helps.
Posted on Oct 26, 2009
SOURCE: LG WM2277HW Thermistor (tE) issue
To be more specific, unplug unit. Behind the machine are two plastic kick plates, remove to slide off the top. Once off, two top self tap metal screws and one screw behind panel wall, remove. Remove two detergent screws. Lift electrical panel and set on top of machine. Remove four top screws. Bottom drain has one screw in front, take out plastic cover and one screw in back. Take off rubber by opening door. With a screw driver, prey and lift up the brass spring ring and remove. Then the front panel should slide up and out. Be careful because electric wire is still connected, move to the side of unit. You will then be able to find the thermostat. Unplug and replace, you will need to use the same rubber bushing. Took me an hour, I’m not an appliance repair guy.
Posted on Feb 09, 2010
jyackle5
  • 8197 Answers
SOURCE: manual for LG Tromm wm2277hw
You can get the manual on the link below.
http://www.manualsonline.com/mdownloads/2cae013d-c99d-4af1-a802-a2d4c42197df.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 29, 2010
I have a LG front load washer model #59WD1653 LG WM2277HW I keep getting an error message of LE I have misplaced my Manuel. What does that mean
Google is not your friend, but can still be helpful.
https://www.manualslib.com/manual/409239/Lg-Wm2277hw.html
May 30, 2017 | LG Washing Machines
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Lg tromm wm2277hw no power
The main control board has a led light onit see if itit's lite if you are sure you have a good outlet board probably bad .lite should be on
Dec 10, 2015 | LG Washing Machines
No power for lg wm2277hw
Power supply has failed to the panel board and it can due to failure of the board, failure of the surge filter or the power circuit.
check the panel and if there is short within the board then the panel must be replaced
Jan 16, 2013 | LG WM-2277HW Front Load Washer
WM2277HW LG Tromm washing machine won't start. Finding correct parts is not so easy. Why?
At 14+ appliance years of age, it doesn't make economic sense to repair it.
Mar 06, 2017 | LG WM-2277HW Front Load Washer
Wm2277hw pcb. looks like there is a fuse on it. can it be replaced?
No, the fuse is encased and cannot be replaced. You have to change the whole board. Sorry.
Aug 23, 2011 | LG WM-2277HW Front Load Washer
I have a WM2277HW machine. I cannot get the machine to turn on. There is no electric outlet problem. Is there a reset button for this machine?
its in the ecu inside under the top cover,if you remove the top cover,then the board is under a plastic cover in the left rear from the front,if the little red LED indicator on the board isnt lit,then either the small board to its left where the power cord connects is bad or this main board is bad and needs replacing
Mar 03, 2011 | LG WM-2277HW Front Load Washer
My LG washer wm2277hw does not drain water and
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | LG WM-2277HW Front Load Washer
Lg wm2277hw washing machine
sorry to say it but i think you still have a faulty hall sensor.
Try another one and send the last one back as being faulty.
It means the motor gets the power but the hall sensor stops it dead in its track
Jul 08, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
