Question about Brother MFC-J6910DW new mfc-j6910dw clr inkjet p/s/c/f printer 1200x6
Brother mfc-J5910DW paper jam
Paper jam front and rear cannot clear
  • 3 Answers
SOURCE: I have a brother MFC 8440
Have you checked the back paper door?, the paper tray?, and the drum/toner unit? If a paper was torn out of the machine, you may not be able to see the piece that is still triggering the jam signal. You can also pull down the paper guide around the orange fuser roller through the back door by pulling it gently to the left.
Posted on Sep 14, 2008
  • 133 Answers
SOURCE: Paper Jam
what you need to do is pull out the drum and remove the paper that you can see.
just pull out the drum unit harder.
Posted on May 23, 2009
  • 133 Answers
SOURCE: message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Posted on May 29, 2009
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
  • 300 Answers
SOURCE: my brother mfc 465cn keeps saying paper jam. I do
The paper sensor is either stuck or dirty.
Just open it and follow the paper path and you should see where it is.
Otherwise, the sensor may be bad.
Posted on Apr 18, 2010
Paper jam at the rear of my Brother 5910DW printer The paper doesn't go through the roller at the back.
Don't fill the paper all the way to the top. Just load half the tray and try it. Also make sure the top tray for faxing is clear of any paper.
Nov 10, 2014 | Brother MFC-J5910DW Color Inkjet...
How to enter maintainance mode in mfc-j5910dw
HI Nicholas,
Please turn off printer and unplug power cord...now check the papaer feed tray, roller assembly area if accessible and the area where the carriage moves to and fro for any bits of paper r paoer clips..also blow some air to ensure if there is anything stuck it comes out.also you may open below link that has illustrated steps for the areas you need to check for stuck paper Paper Jam Brother OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 11, 2014 | Brother MFC-J5910DW Professional Series...
Brother mfc 8670 paper jam duplex
remove the small, or scratch into pieces inside the duplex to clear the paper jam.
Feb 10, 2014 | Brother MFC-8670DN - 30 PPM Multifunction...
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
Error 30 after jammed paper on brother MFC-240c
Open the front and the rear panel and make sure there is no bit of paper jammed. Also make sure there is no dirt in the printer roller
Jul 03, 2009 | Brother Multi-Function Center MFC-240C...
Back cover open message on brother mfc 7820n
Had same problem. Closer inspection revealed bit of paper out of sight. Removed the toner cartridge and worked to free torn paper. Then restart. Hope it helps.
Dec 15, 2008 | Brother MFC-7820N Printer
Paper jam and now printer wont work since all paper has been cleared out of printer
paper pick-up rollers may be warn out.replace rollers.tell me the company &model no.
Aug 04, 2008 | Office Equipment & Supplies
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC-J6910DW new mfc-j6910dw clr inkjet p/s/c/f printer 1200x6 Logo
23 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
